Question about Whirlpool Dishwashers
I have a whirlpool dishwasher and the little door that holds the little pack of soap doesn't work right the little pack doesn't desolve.
  • Whirlpool Master
  • 19,396 Answers
Hi.
If the drawer does not open at all, then the problem is the drawer mechanism itself or the detergent drawer switch connected to the electroni control module. In that case the door must be taken apart to test and eventually replace the part. The switch can be tested energizing it and observing the action on drawer. Most dishwashers use a low voltage mechanism. Please refer to service manual for specific model. Most drawers are operated thanks to a spring installed in the drawer. Check that the spring is well in place.
If the drawer releases too late and/or tablet does not dissolve, then the switch may be OK, but the drawer may be obstructed by baskets, the detergent may be incorrect, or the water may not be heating or filling. In that case follow the indications here: The soap dispenser drawer.
To find parts and diagrams try entering the full model number (as from service tag) in the websites listed at the link below:
Enter the model number ...
Regards.
Ginko.
Posted on Dec 30, 2010
I have a whirlpool dishwasher DU920PFGZ0 and the detergent dispenser door doesn't open all the way to release the soap
Is there a tall dish/cookie sheet/pan blocking the dispenser door from opening fully? Check inside the rack of the dishwasher to see where the dispenser door lines up.
Oct 11, 2011 | Whirlpool Dishwashers
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
The soap dispenser on my whirlpool dishwasher sticks doesn't always open far enough for the tablet to dispense. how do i fix it
I always bust the little tabs befor i put them in, or just toss them into the machine bypassing the door altogether. Works just fine. That little door is for powder or liquid most times.
Oct 10, 2010 | Whirlpool Dishwashers
Soap door won't open
make sure nothing is in front of the door run unit with out dishes and lower rack in it see if it opens
May 14, 2010 | Dishwashers
Kitchen Aid Dishwasher KUDS03ST We built our house and had this dishwasher sitting in the box for almost 2 yrs before finally using it. After finally installing it I find that occasionally the door to the...
i have seen a lot of dishwashers that have this problem if they have a flip open lid for the soap .. often its caused by the top adjustable tray blocking the soap door from opening .. i put a camera inside to figure out what was happening ..in some cases all i had to do was raise the top basket .and make sure the basket is fully back before closing the main door .. it still blocks the soap door but allows it to open far enough to get the detergent washed out .....also i had to avoid putting large items in the corner where the dispenser is located .. they dont block the door but do reduce the water flow that could otherwise get into the cracked open soap door .. i reported this problem to my dealer .. and he stated that he didnt really want to know .. if he knows then he is obligated to do something about it .. which he claims he cant .. i demonstrated the problem on several brands at the store to whoever would listen .. some dishwashers have a sliding or rotating soap door .. those work better .. a few have a cut out in the top basket to clear the soap door .. .. the design of many washers are so similar that you might believe they are all made by the same manufacturer .with the same error in design . many seem to have that problem .. when the door doesnt open properly then the soap may become wet but not desolved .. somtimes it does partially desolve in the rince cycle .. i would think that is a hazzard .. you would have soap residue left on your dishes that you might ingest .. the dishes might look clean however so you may not even know anything was wrong ... letters to the manufacturers got me nowhere .. we struggled with that machine for a year .. we learned the tricks to make it work but during a big party our guests and relatives didnt know that .. there we were ready to serve with all dirty dishes ..after that happend a few times we bought another new dishwasher .. but the one delivered had the same problem .. what frustration .. so we sprung for a really good unit from bosch .. it has a sliding door and works perfectly .. very happy now ..
Oct 06, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Soap doew not disolve
first start the washer listen for it to fill then open the door and see how much water is in it let me know but hold my rating till we finish
Jan 31, 2008 | GE 24 in. GSD3210Z Built-in Dishwasher
Soap does not desolve
check that the spray arms are turning and that the holes in them are not clogged, if you line them up pointing towards the front let the machine fill then as it starts to wash open the door and you should see the arms slowing down, if they are okay then check the water level which should just lap the filter at the bottom
Jan 07, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
I put the wrong dishwasher on my last post.
Dec 01, 2007 | GE 24 in. GSD3210Z Built-in Dishwasher
Dishwashers Logo
144 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
