Burnt terminals and connectors - Heating & Cooling
  • 2,133 Answers
Do rewiring and replace connector. But ask yourself-why it's burnt? The reasons are
1. Loose wiring. 2. Under size wiring. 3. Very High voltage.
Posted on Dec 30, 2010
2004 ford freestar front blower motor will not come on. Windshield wipers only work occasionally
Pull the control switch out of the dash and check the switch connector for burnt connectors terminals, it will be be discolored, if you do find the switch burnt replace the switch and buy a repair connector from Ford. If the connector is ok then replace the blower motor resistor near the blower motor, it can cause this problem as well, in fact do that first, the blower resistor module is only about $18.00 (Source Rockauto.com). the wipers are controlled through the BCM (body control module), it can be tested with a scan tool. Below is a picture of the blower resistor module.
Apr 03, 2017 | 2004 Ford Freestar
Why does my fuel pump keep going out ? - 2003 hyundai elentra
CHANGE FUEL FILTERS MORE OFTEN OR THE PUMPS ARE OF LOW QUALITY. ALSO MAKE SURE YOU CHECK THE PIN TERMINALS CONNECTORS TO THE FUEL PUMP , THE ONES RIGHT ABOVE THE FUEL TANK , LOOK FOR SIGNS OF HEAT OR BURNT PLASTIC CONNECTORS, THAT MOST LIKELY WOULD CAUSE IT, FAILED FUEL PUMPS PUT A LOT OF STRAIN AND RESISTANCE ON THE METAL CONNECTION TERMINALS
Aug 27, 2011 | Hyundai Elantra Cars & Trucks
I have a whirlpool inglis dryer that is about 5 years older and I have a 3 prong electrical cord, in the back of the dry were the electrical cable connects into the dryer (There is 3 connection locations)...
Hi johnebrenner...
Most likely cause of the wire being burned is a loose and arching connection.
I would recommend that you replace your existing cord and wire with new ones and make sure to tighten your connections very tight, but do not strip the screws by over tighting..
Please take time to rate me
Aug 23, 2011 | Whirlpool Inglis IP8200 Dryer
Change batteries . light show up on control and go out when toogle switch moved chair will not move or make a sound
Hi. Sounds like a loose battery terminal or a faulty in-line battery connector, or a loose terminal on the controller.
Could also be caused by a faulty set of batteries that can't supply enough current ( amps ) to drive the machine.
Could be a siezed brake solenoid stopping the motor from turning. A burnt out motor will also cause this problem. A burnt out motor will have a strong smell of burnt varnish.
What is the history of this machine, has it been sitting unused for a while> Have you had any other problems?
Good luck. Neil.
May 29, 2010 | Golden Technologies Alante' Power Chair
2004 silverado 1500. interior fan control switch
check connector at blower resistor under glove box.. you will find one or more terminals burnt or the connector melted...will need to replace connector and resister,.
Dec 20, 2009 | 2004 Chevrolet Silverado
LG display is completly black, however the phone works
The problem is either in the the flex ribbon connector, connector terminals or LCD itself. Disassemble the unit then check the flex ribbon connector for any crack or damage. If no apparent damage is found, clean both the flex terminals and the connector terminals. Resoldering the connector terminals is also suggested. If no result, LCD is damaged, replace it.
Oct 18, 2009 | LG Shine CU720 Cellular Phone
Burnt out starter, how do i replace it
To Remove:
  1. Disconnect the battery ground cable.
  2. Remove the speedometer cable and the shift cable.
  3. Disconnect the starter motor connector and terminal.
  4. Remove the starter motor assembly.
To Install:
  1. Install the starter motor assembly.
  2. Connect the starter motor connector and terminal.
  3. Install the speedometer cable and the shift cable.
  4. Connect the battery ground cable.
Oct 01, 2009 | Hyundai Motor 1996 Elantra
Burnt out wire at terminal connection - I think!
cut the wire back just to where you get fresh copper... twist the wire very tight turn it under the screw in a clockwise direction ...put the screw in very very tight...if you have terminal connectors you can use them also..the trick is to make all connections very tight
Aug 08, 2009 | Maytag MGR5880BDS Gas Kitchen Range
Saturn sc2 wont start
You most likely have a burnt terminal in your Inside fuse block.Easiest way to check this is to remove the console trim panel next to the drivers side front of console,just pulls loose.Then while trying to start the engine reach down & wiggle the wring going into the front 68way connector.If it takes off & starts to crank you have a burnt terminal in the fuse block.If you remove the front connector (68 Way) there are 2 of these 68 ways in that block.You can look inside at the male terminals you will see one terminal with plastic melted around it.If you see this,that''s your problem!! You will need to find a used Fuse block at junkyard with same Part #.Very important to get same part!! Hope This helps
May 14, 2009 | 1995 Saturn Sc
94 suburban no power at ignition
test the ignition switch or look for a burnt connector to the switch, if the connector is burnt/melted replace the connector and the switch.
Mar 06, 2009 | 1994 Chevrolet Suburban
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
