I have a 7.75 hp Elect Start Intek OHV Craftsman snowblower, and after many successful years it has decided this year to simply not start. Even with the electric start iniitiative, it sounds as though it's about to start, but never completely engages. Any suggestions?
SOURCE: Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
Posted on Dec 31, 2008
SOURCE: Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Posted on Jan 19, 2009
  • 5 Answers
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: LOOKING FOR A DEW CROSS REF OIL FILTERS TO REPL. C...
motorcraft fl-400 can buy at walmart
Posted on May 23, 2010
  • 146 Answers
SOURCE: starter gear doesn't move up to engage flywheel gear when started
The solenoid does two things -- it closes an electrical contact to run the starter motor, and also pulls a lever to slide the motor gear up to engage the flywheel. Since the contact is closing, the solenoid itself must be OK, but the lever could be broken, or the sliding gear could be binding or stripped. Since you're looking at a probable replacement, try cleaning with compressed air, then squirting some WD-40 into the starter gear area - you could get lucky! Otherwise, you can replace the starter/solenoid assembly -- you can find replacements on eBay for about $80. Less expensive but more time consuming is to remove the assembly, disassemble, and replace just the defective parts if you can find them. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 15, 2010
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: will only start with choke on and after warm (chok...
If it has a plastic intake manifold there is your culprit. The flanges warp and produce vacuum leaks and all three.
Posted on Nov 06, 2010
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a 25 h.p. Briggs intek . The starter tries to engage but will click once and does not turn the motor. I have a new solenoid and a new battery. The starter and starter wire will get warm when tried...
sounds like starter is bound up,take it off engine and apply battery voltage to battery cable connection on starter and see if starter will turn over if not the starter is bad
May 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman Ride-on hard start, loss of power
you have to get piston to top dead center, there should be 4 thousandths of clearance between rocker and valve on both valves.
use two wrenches to tighen
Sep 02, 2009 | Craftsman Garden
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
