Question about Frigidaire GLER341A Electric Dryer
Frigidaire LEQ332DSO Squealing Noise
Help...I have a 3 year old Frigidaire dryer that has just staretd making a squealing noise when it is drying clothes. The clothes dry, nothing burns, but the squaling noise coming from it is unbearable. Can it be oiled or something? It is a front loader, stacked on top of the washer. Any help you can provide would be terrific.
  • Anonymous Dec 10, 2008
    Drying produces Squealing Noise
    Genius:
  • 1,028 Answers
Sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Posted on Jul 08, 2008
Frigidare Gallery Dryer FSE748GFS1 makes squealing sound intermittently when drying. Is there a repair manual for this dryer?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 20, 2011 | Frigidaire Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Dryer squealing
probably some was in a pocket and is now jammed in the seal you will need to take the whole cas(sheet metal ) off of the unit to access the tumbler seal
Jan 06, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Squealing noise on start up drying still works
This dryer needs to be taken apart to lubricate any and all moving parts. Idler pulley and rollers, if they are worn out in any way, replace them.
Also, consider a new belt.
Nov 16, 2009 | AEG T58840 Dryer Electric
MAKING SQUEALING NOISE
heatman101
fgsj
Oct 19, 2009 | Whirlpool GGW9250PL Gas Dryer
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Dryer louder than used to be, does it need service?
The belt may be worn and squealing because it is slipping.  When it warms up it stops slipping.  It will have to be replaced soon. A worn bearing on a support wheel could also cause intermittent noise.
May 29, 2009 | Amana ALE643RB Electric Dryer
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
Hoover Nextra 8 dryer making a squealing noise
you have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Dryers
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
584 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Electrolux
Electrolux
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
