Question about JoWood Productions Transport Giant Gold Edition for Windows
Won't run on XP or Windows 7 - any ideas? - JoWood Productions Transport Giant Gold Edition for Windows
Genius G-Pen 560 Tablet Driver won't Install on Windows 7
If you have Windows 7 Professional or Ultimate you can install XP mode and Windows Virtual PC on top of Windows 7 and run XP mode.Install the drivers on XP mode and you should be able to use your tablet.
Virtual PC and XP mode are available free of charge on the Microsoft web site. The site requires authentification to verify that your copy of Windows is genuine.
Apr 03, 2012 | Genius G-Pen 560, USB 4.5 x 6 tablet with...
CANNOT PLAY BICYCLE PINOCHLE SINCE UPDATING COMPUTER PLAYED BICYCLE PINOCHLE ON WINDOWS 98, CANNOT PLAY ON WINDOWS 7
Unfortunately, due to changes in the OS and how programs run, a program written for Windows 98 will not run under Windows 7 directly.
Even the compatibility mode will probably not work unless your version of Bicycle Pinochle for Windows was written for XP as well as Windows 98. (The WinXP version would possibly run under the Windows 7 32-bit version; it won't work under the 64-bit OS. To find your version of Windows 7, click Start > Control Panel > System and Security > System. If the version title ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit version.)
You need to either upgrade your game software or get an older version of Windows running somehow. This could be a virtual computer (runs inside your Windows 7 computer if your hardware permits it), a second machine or a dual boot computer. For Windows 98, you will need a licensed version of the OS for any method. Check a nearby Windows User's Group to see if anyone there has the OS.
If your version of Pinochle could run under Windows XP and you have Win7 Pro or Ultimate (or upgrade to them), you can run a virtual version of XP for free. In this case, download and install (in order) Virtual PC and XP mode from Microsoft. Then install the software in the XP computer as if it were the only computer running. (The compatibility mode didn't work inside XP mode for software written for Windows 2K so I doubt a Win98 program will work.)
An XP version of Bicycle Pinochle was offered by Microsoft: http://www.microsoft.com/games/bicycle/card/ . A Windows 7 version of Single Deck Pinochle is here: http://www.sac-irca.com/pino.html .
I wish that I had better news for you.
Oct 23, 2011 | Expert Software Bicycle Pinochle for...
System won't recognize downloaded driver, I have installed an update provided on HP's site, but it still won't work. trying to install on a windows 7 computer. had installed it earlier on a...
When downloading a printer driver from HP you will need to ensure that you are selecting the correct OS (eg. Windows 7) and the appropriate version (eg. 64 or 32 bit operating system). These drivers are different and using one on the other will not work.
Windows XP drivers also will not work properly in a Windows 7 environment and the majority of Windows XP drivers are 32-Bit.
Sep 06, 2011 | Office Equipment & Supplies
Topics Instant Play Piano will not load on Windows 7 and I no longer have computers with previous versions (XP, etc.). How can i get this to work on Windows 7 computer? Is there a fix or am I just out of...
You may try Topics' site, it is possible the either have a workaround or some kind of solution that would allow you to install it on a Windows 7 machine. Unfortunately, unless you have Windows 7 Professional or Business, you won't have the virtualization part of W 7 that allows you to run Windows XP within Windows 7. Sadly, a lot of good software became obsolete this way. Definitely had a few myself that got the axe on the move to 7.
Aug 24, 2011 | TOPICS Entertainment Instant Play Piano...
I have replaced my windows xp with windows 7 and my tigerwoods 06 won't play. and it did with windowds xp.
Download the FREE Windows 7 XP Mode, install it, then reinstall your software in XP Mode following the XP Mode Application Instructions. Another alternative is to use the FREE XP mode virtual machine under Windows 7. You can then load software that is compatible with XP But not Windows 7 in the XP virtual machine.
Works excellently
http://www.microsoft.com/windows/virtual-pc/download.aspx
Jul 02, 2011 | Toshiba Satellite M65-S809 Notebook
When I try to install the program, it says that I may to use a 32-bit system. I have Windows 7, 64-bit. Does this mean that the game won't work on my computer?
Maybe so. As alot of programs and software still recognizes windows xp and not windows 7. I have encountered alot of similar problems with windows 7 and the same program runs well with windows xp.
thanks,
G.
Jun 27, 2011 | The Learning Company Arthur's Thinking...
Sir i want to check our lenovo 3000 that it contains correct RAM,HDD and everything in it. and another problem is that i have os win 7 proffesional so that i am not able to install c language in it.
Yes it looks like it, to run the C language you will need to dual boot Windows 7 and Windows XP. Or install only WIndows XP. Another idea is to install a Virtual Windows XP Operating system. Therefore XP running in a Window of Windows 7. Called virtualization.
However virtualization is not possible on this model of Intel CPU.
Take care!
damnor01
May 28, 2011 | Lenovo 3000 N200 0769 Intel Celeron 530...
How can I run my old copy of Monopoly from Infogrames on Windows 7?
Works in my Gateway Netbook running a Win 7 Starter OS, Won't even install on my Dell N5010 running a Win 7 Home premium OS. BUT IT does work in Safe mode on the Dell laptop. Tried compatibility mode. Have no Idea why it won't install.
Feb 13, 2011 | Infogrames Monopoly 3 for Windows
Sybase Powerdesigner 9.5 Windows 7
PowerDesigner 9.5 wil load on Windows 7 but it won't run. I was able to get it to run by installing it in the virtual XP environment on Windws 7.
For this to work,
Must be running Windows 7 Professional or better, and
Your machine has to allow virtual machines (BIOS Setting).
You will need to download 'XP Mode' and indows Virtual PC' from Microsoft.
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
You will be able to run PowerDesigner 9.5 and oter applications that will not run in the Windows 7 environment but ran previously in the XP environment.
Mar 15, 2010 | Sybase Powerdesigner 9.5 (20330-01-0950)
Aureon pci 5.1 windows 7 drivers
That's because windows 7 is not supported by the card. Try running in XP compatability mode.
Sep 17, 2009 | Genius Soundmaker Value 5.1
JoWood Productions Transport Giant Gold Edition for Windows Logo
145 people viewed this question
Top JoWood Productions Video Game Consoles & Games Experts
James Wishart
andrewcahoon
Carlos L. Burgos
Carlos L. Burgos
Are you a JoWood Productions Video Game Console and Game Expert? Answer questions, earn points and help others
