Question about Pari Proneb Ultra II Compressor Nebulizer System
Air is no longer pushing out with same amount of force.
    Problem Solver:
  • 12 Answers
It needs to cleaned - clean the tubes and medication chamber with warm distilled water and change the air filter.
Posted on Jan 01, 2011
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
What is aerodynamics
Aerodynamics often refers drag, or the resistance of a body to move through air (considered a fluid). In your case, though, an automotive spoiler uses the deflection and displacement of air molecules to produce a downward force on the chasis. This is an aspect of Newton's third law, which deals with the generation of an oposite and equal force in relation to the amount of force necessary to deflect the air upward. The retractable wing on the Boxter raises at high speed to provide greater downforce (hence greater stability) at these higher velocities.
Jun 11, 2014 | 986 Boxster Aerodynamics: Porsche Boxster...
When I push my red button in it shut off the fuel and wont stay going
this is caused by a bad thermo coupling. just to make sure that it is in fact bad - hold down the button for about 20 seconds while the heater is going and if after that amount of time the unit still shuts down when you release the fuel button - then replace the thermo coupling.
c...
Jan 03, 2011 | All-Pro Propane Garage Shop Heaters - All...
Is there supposed to be flame coming around the cone of a 115,000 btu reddy forced air kerosne heater?
no. the flame should be behind the cone. If it passes the cone, this means that there is too much air. simply turn the air pressure screw until the flame no longer comes beyond the cone.
Nov 27, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
The clutch won't disenguage
If your clutch won't release properly, it will continue to turn the input shaft. This can cause grinding, or completely prevent your car from going into gear. Some common reasons a clutch may stick are:
  • Broken or stretched clutch cable - The cable needs the right amount of tension to push and pull effectively.
  • Leaky or defective slave and/or master clutch cylinders - Leaks keep the cylinders from building the necessary amount of pressure.
  • Air in the hydraulic line - Air affects the hydraulics by taking up space the fluid needs to build pressure.
  • Misadjusted linkage - When your foot hits the pedal, the linkage transmits the wrong amount of force.
  • Mismatched clutch components - Not all aftermarket parts work with your clutch.
Mar 21, 2010 | Oregon Scientific Electric PTO Clutch for...
Clutch want catch any gears
Another problem associated with clutches is a worn throw-out bearing, sometimes called a clutch release bearing. This bearing applies force to the fingers of the spinning pressure plate to release the clutch. If you hear a rumbling sound when the clutch engages, you might have a problem with the throw-out.
Mar 04, 2010 | 1998 Chevrolet Cavalier
Catastrophic failure of clutch on 2007 Accent SR
But most of these problems should have been detected the first time you went in. So it can probably be traced back to the mechanic, not you. I would have another person look at the issue and see if you can't get a second opinion.
Mar 01, 2010 | 2007 Hyundai Accent GS Hatchback
Will not stay lit
You have a bad gas hold on valve. You can get one at www.reddyheat.com Let me know if I can be of more help.
hardrocko
Thanks for using FixYa
Feb 25, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Water dispenser drips after filling glass.
sounmds like you have air trapped in tothe line( formiong pressure behind the line whe nnot in use forcing water drops out, remove the crisper in the refrig campartmant and look for the holding tank either there an air bubble trapped in ther or you havea small leak allowing air inot the system, usually happen right after replacing the filter, instraed of trying to rnn 5 secs on 5 secs off, try with a bigger contaienr to allow constantly running for longer periods of time to hopefully force out the air bubble
Mar 05, 2008 | Amana ACD2232HR Side by Side Refrigerator
Pari Proneb Ultra II Compressor Nebulizer System Logo
380 people viewed this question
Top Pari Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Pari Health and Beauty Expert? Answer questions, earn points and help others
