Question about Precor EFX 546i Elliptical Version 4
I have a EFX5.21si and the ramp will not go up. I have checked the fuses and they are not blown. Does anyone have a suggestion?
93 Camry 4-cylinder
check the 25 amp fuse that had fan rad on it . Check the fuses under the dash. Finally replace the fan switch in the head as it may not be communicating with the CPU to put power through the fan relay
Dec 23, 2013 | Toyota Camry Cars & Trucks
No power
THERE IS A MAIN FUSE FOR ALL AND AT THE BATTERY BUT THE FUSE BOX DOES HAVE A PRIMARY FUSE FOR JUST THAT INCIDENT CHECK AGAIN GOOD LUCK
Jul 14, 2013 | 2003 Ford Crown Victoria
My optavision 9500 hd projector lamp does not come on even though the indicator shows green light. I changed the lamp,but result is the same. Can anyone suggest what the problem may be?
Check with a multimeter if the bulb socket is getting power (CAREFULLY). If not, that is the problem. The relay that turns on the bulb is blown or the fuse to it is blown...check them out...
Jan 01, 2013 | Office Equipment & Supplies
Fuse box diagram for toyota lucida
i need hellp i have no power to my new cd player can anyone help me to tell me which fuse is to the radio please there are loads i dont no which one please help i want to check that its not the fuse that has blown x
Mar 23, 2012 | Toyota Previa Cars & Trucks
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
Aug 26, 2011 | Jamo SUB 200 Subwoofer
Auxiliary ports not working
There are 2 fuses in the rear fuse box. The cig fuse and the Aux/pwr 2 fuse.
Check what you are plugging in the outlets. Phone chargers are a first source of blown fuses.
Aug 27, 2009 | 2007 Chevrolet Malibu SS Sedan New Cars
2000 Mazda MPV radio is "dead"
try pulling all the fuses one at a time and see if any others are blown. if so replace.
Jun 23, 2009 | 2005 Mazda MPV
Xenon lights blown fuse
You could have a problem with the xenon light itself on the passenger side or the wiring running to the light assembly.You could unplug the connector from the light assembly and replace the fuse if it still blows the fuse, its in the wiring harness if it doesn't it problably is in the light assembly. I'm not sure how the lights are configured on the Z if the zenon lamp is replaceable by itself, you can try swapping it out. I haven't had any problems with my Z but those are a few suggestions on troubleshooting your problem.
May 15, 2008 | 2003 Nissan 350Z
Precor EFX 546i Elliptical Version 4 Logo
148 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
