Question about Broan-NuTone CV750 Central Vacuum
Loss of suction. we have checked that there is ni blockage.
Disconnect the incoming pipe from the vacuum power unit and turn the switch on (on the side of the unit) while you feel the bottom of the unit with your hand. If BOTH motors come on and sound normal and are producing suction you should feel the bottom of the canister flex or you should feel suction at the inlet connection.
If the bottom flexes but there is no section at the inlet there is an obstruction in the pipes witin the vacuum unit. A stiff wire with a hook bent at the end is usually sufficient for removing the dust stuck in that piping.
You can also unplug the 110v poser then remove the top cover (only 3 or 4 screws) and visually inspect the motors and piping for failures.
Posted on Mar 11, 2011
Ihave a canister vac. Bought last april low suction
Have you cleared the vacuum hoses
Dec 01, 2016 | Vacuums
Loss of suction on my Ergorapido
thats odd
check if the piping is clear from the dust collection
down to the bottom brush
it does have some sort of dust collection
if it has a filter of any sort check its condition
check the pick up hole in the brush housing
maybe a seal is leaking
Sep 04, 2016 | Vacuums
Why has the vacuum cleaner lost power?
If by power loss you mean loss of suction power then I would check and either clean or replace ALL of the filters. Check and clean the rotating brushes and make sure all of the tubes are clear. Almost all suction loss is down to some form of blockage to the air passing through the cleaner and unless the air can pass freely through and exhaust properly, it will not pick up efficiently.
Jan 01, 2016 | Bosch Vacuums
What to do if Vacuum losses suction?
There may be leakage somewhere in the intake path.
Jul 15, 2014 | Dirt Devil Vacuums
Electrolux pet lover loss of suction through the hose
I would use a snake for plumbing (sinks) and feed it down the hose to find and clear this blockage if you can remove the hose compressed air may also work.
Dec 18, 2012 | Vacuums
Suction perfect when in upright position, but when tilted to actually clean there is total loss of suction - cannot see blockage anywhere. Thanks for your help.
If you are confident there are no blockages, look underneath, where the brush is, and you will see a short length of reinforced clear plastic hose. This often develops a split which results in loss of suction. You can pull the hose off at the motor end and then unscrew it from the brush end to examine it thoroughly. If you find a split, it's best not to try and tape it up (except as a very temporary measure) - a new one is not expensive.
Feb 26, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The vacuum does not operate normally, there is no suction, where can I get it service. We live in Toronto, it was purchased this fall.
If there's no suction, you should first check the User Manual for how to clear blockages (this is the most common suction-loss problem). If you're certain there are no blockages, the machine is still within its warranty period so you should return it to the place where you bought it.
Feb 05, 2010 | Vacuums
Power Loss - Suction Loss
Hi
Its cutting out because its overheating.
Change the filters and check the base and the hose for blockages
Feb 14, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of suction
There is a blockage . Check the small hose under the sole plate
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction
If the wand alone causes a suction loss, there are only a couple of issues:
  • leakage
  • blockage
If it is leakage, remedy the defect or install the wand correctly.  If it is a blockage, you'll have to find and remove it.
Jul 14, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Broan-NuTone CV750 Central Vacuum Logo
117 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
