Question about Weber Genesis Silver A Grill
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Posted on Jan 09, 2011
  • greggk46 Jan 13, 2011
    This is a good solution, but did not work in my case. Weber sent me a new regulator and hose. I'm way past the warranty period, but they sent it for free. Now the grill works perfectly.
Weber genesis silver B won't get hotter than 450
Yes diaphram could be split causing vent to pass gas .
Aug 08, 2012 | Weber Genesis Silver B Grill
I've had my grill for a few years and when i turned it on last night, i could barely see the flames and i had both burners on hi. I cleaned (took a wire brush) to where the flames get out and still...
You may have to recheck the tank for full. If you forgot to turn off the tank after the last time you used the grill, the tank could have leaked down. I always keep a spare full tank for just those types of problems. If the tank is full, then the regulator may have a problem. That grill should be able to get over 300 degrees.
Jul 07, 2011 | Weber Genesis Silver A Grill
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
It doesn't seem like the burners are getting a full supply of gas. Flames are very small. Tank is full
The tank might be too full. Those guys that fill the propane tanks will sometimes overfill them. Try letting out some gas from the bleeder valve screw until you do not get any more liquid.
Sep 19, 2009 | Weber Genesis Silver C Grill
Weber grill wont heat past 350 degrees. Tank is full. Not leaking gas.
either your regulator is not hooked up to the tank all the way try to turn tank off make sure all knobs are turned off disconnect tank then reconnect turn tank on and try again if this doesnt work the regulator is bad
Aug 09, 2009 | Weber Genesis Silver C Grill
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Mar 23, 2009 | Weber Genesis Silver C Grill
Weber BBQ does not get hotter than 300 degrees
Might be easy! diconnect hose from tank ..and re-connect... this has worked for me in the past
Mar 15, 2009 | Weber Genesis Silver B Grill
Cannot draw gas fully out of my tank
Yes,it definitely sounds like the regulator to me.First check to see if the regulator is still under warranty,if not replace regulator with a Weber or comparable one and try again.
Nov 21, 2008 | Weber Genesis Silver B Grill
Weber Genesis Silver A Grill Logo
799 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
