Question about Microwave Ovens
The drawer front of my bosch HZWE290 warming drawer has become loose and I can't figure out how to repair it.
Where is the warming drawer sensor in my kitchenaid oven?
If you wish to get some details about microwave oven repair and error codes then check the following link
http://electro-medical.blogspot.com/
Jul 27, 2016 | KitchenAid Microwave Ovens
Bosch microwave door sags. It's difficult to open, close or start. Can it be adjusted?HMB5050/01 Photo is of right lower corner of door showing the misalignment
Any microwave with a mis-aligned or loose door is probably leaking excessive microwave energy, and should not be operated unless a leak test is conducted using a calibrated meter.
Unless you own such a meter, the oven should be inspected and repaired by a qualified technician.
Jul 26, 2016 | Bosch Microwave Ovens
How i can fix problem?
What you call all functions, I think it's only the front, the keys and the display. I think the main fuse or circuit breaker has tripped. Because when the magnetron does not work nothing will become warm.
microwave ovens should not be opened by normal users. The voltage used to get the magnetron fire is very high and can kill you when you touch it. To reach this voltage, there are capacitors inside, that can hold this voltage for a long time. So even with no power cable attached inside can be dangerous voltages. Please don't try to do this yourself. If you want it repaired visit a repair centre, but opening and replacing the defective parts can cost more than a complete new microwave. So first ask what it could cost you if you bring it in for repairs. And check what a new one will set you back.
Sep 27, 2014 | Daewoo KOR-860A Microwave Oven
How to reset dacor mwo30s warming drawer
If for some reason you don't still have your owner's manual, you can find it here.
Nov 30, 2013 | Dacor MWO30S Millennia Series Warming...
Thermador warming drawer takes 45 minutes to reach 190 degrees on high setting! That can't be right! Tech support said it should be 220 degrees on high and should take 20 minutes to fully heat.
I recommend that you go with your microwaves and claim to fix it. This can be a problem with magnetron, or power diode, capacitor faulty, or thermostat.
God bless you
Oct 27, 2013 | Thermador 30 inch Convection Warming...
My fridge is warm doesnt cool down the things inside only the chilly colder box is cold and it freezes down the meat
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 19, 2011 | Bosch Microwave Ovens
Micro pops and lites flash. i have a thermador combo oven warming drawer and micrwave.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 01, 2011 | Thermador MBES Microwave Oven
Hi, I let a friend use my Bosch 5600 PSE key less
you can't drill counterclockwise the bits are setup to drill clockwise and the chuck would become loose. try using two wrenches to free up the chuck then spray a little wd40 in it it is just bound up
Nov 05, 2009 | Microwave Ovens
Bosch range front glass smashed
open the oven door and look on the sides where the door meets the oven. also slide open bottom drawer and look where drawer meets oven. hope this helps!
Aug 29, 2009 | Bosch HMB402 Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
