Question about Western Digital WD Scorpio Blue WD2500BEVT - hard drive - 50 GB - SATA-300 SATA II
My WD2500BEVT beeps (3beeps pause 3 beeps pause) a number of times then sounds like windows recognizes the drive but does not.
  • Western Digital Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Dec 30, 2010
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
My hard drive doesn't boot up as normal. When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps. Numbers 3 and 4 on the hard drive are...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
hope this helps
Dec 29, 2010 | Computers & Internet
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
I have dh55tc, i7 860, 4gb transcend ram, xfx hd 5770, tagan stonerock -u37 600w psu, Its assembled in March 2010 & ran fine for 5 months. One day while watching movie it suddenly froze, i restarted...
3 beeps means that it's a RAM fault. If your memory worked just fine in another pc then it's the fault of the memory controller of the chipset on the motherboard - either the memory slot is loose (move the stick in the slot and try again) or the chipset itself is failing. That can't be fixed, the mobo is dead, replace it.
Nov 19, 2010 | Intel DH55TC Motherboard
Toshiba Satellite m55 that will not pass post, 3-4-3 beep code
Sound like your Video Card has gone down i think it cant find the VGA bios
Nov 30, 2009 | Computers & Internet
ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Aug 27, 2008 | HP Compaq dc5100 PC Desktop
Western Digital WD Scorpio Blue WD2500BEVT - hard drive - 50 GB - SATA-300 SATA II Logo
988 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
