Question about Lexmark E260 Laser Printer
My Lexmark E260dn printer is making a loud grinding sound on start-up and when printing. I have removed the toner cartridge and photoconductor kit and checked for paper jams or foreign material in all accessible areas, but found nothing. I can find no evidence of worn gears. What could be causing this really aggravating noise? It sounds as though it could be causing damage somewhere in the printer.
  • 1126 Answers
SOURCE: Our 1720dn continually flashes,
Open front cover. Press and hold the 'CANCEL' button ( X ) until all lights flash in sequence. Close the front cover.
Posted on Dec 03, 2009
  • 217 Answers
SOURCE: Dell 1700 is giving me an error about the Toner.
The printer has no way of knnowing that you have changed the Photoconductor Unit, unless you tell it (as there is not chip on the Photoconductor).
The Photconductor reset procedure is as follows.
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
Posted on Apr 20, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: need to reset photoconductor kit
    How to reset PC kit:
    1. Open the front door cover while the printer is on.
    2. Press and hold the Cancel button until all the lights starts flashing.
    3. Close the front door cover.
    Print a test page to check if the counter has been reset.
    If still not reset, follow the instructions carefully in this article found in the Lexmark website. Just click on this link: http://bit.ly/anGz2O. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    Posted on Apr 26, 2010
    • 217 Answers
    SOURCE: Power up init fails
    When you replaced the photoconductor, did you go through the procedure to reset the photoconductor counter ?
    There's no chip on the photoconductor, so you need to reset this manually
    Photoconductor Reset Procedures:
    Step 1:
    Open the front door and hold the
    Cancel button until all lights begin to cycle.
    Step 2: Close the front door. The warning
    clears and the counter resets to zero.
    Step 3: Press Continue to resume printing.
    • 53 Answers
    SOURCE: Photoconductor kit? Dell 1700 printer
    The photoconductor kit is another word for the drum or imaging drum. All three words refer to the same part.
    Here is a link from the Dell site for this model.
    http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=dhs&sku=310-5404
    Once you replace the drum, the printer has to be manually reset. If this is not done, the printer will continue to give this print out. By resetting it, the counter is set back to zero. The drum is good for around 30k prints.
    From the Online Manual for the 1700, to reset the counter:
    http://support.dell.com/support/edocs/systems/1700n/en/index.htm#online_documentation
    To reset the counter, press and hold the Cancel button until all lights flash in sequence.
    NOTICE: Resetting the imaging drum's counter without replacing the imaging drum may damage your printer and void your warranty.
    Posted on Jul 09, 2010
    I have problem with printing. My printer prints with black spots sideways and in the middle . I have changed my toner cartridge since 1 week before . How can i solve this problem ?? I would like a rep
    The e120 has a second supply part, called a photoconductor kit. It sounds like the one in your device is worn out. Go to Lexmark.com, enter the name of your printer in the supply finder, and look for a photoconductor. It installs as in the same area of the printer as does the toner cartridge. Order, replace, and it should solve your problem.
    Nov 12, 2014 | Lexmark E120n Laser Printer
    PC life warning
    This means that the photoconductor has reached the end of life; on other printers, this is called the drum. It transfers the toner onto the page during printing so that it will fuse to the paper. The replacement is $70 from Lexmark: http://www.lexmark.com/US/en/view/Ink/Toner%20&%20Supplies/X340,-X342-Photoconductor-Kit/catId=cat170003-category&prodId=3599-product . The replacement should last about 30000 pages.
    To replace the unit after you get a replacement, open the front cover and pull out the print cartridge assembly by the handle. Put the assembly on a flat surface. Remove the toner cartridge by pressing the button on the assembly and pulling on the handle. Open the new photoconductor kit and snap the toner cartridge into place on it. Then slide the new assembly into the printer. The steps are shown here: http://support.lexmark.com/index?page=answerlink&userlocale=en_US&segment=SUPPORT&locale=en&url=http%3A%2F%2Fsupport.lexmark.com%2Findex%3Fpage%3Dcontent%26id%3DSO4365%26actp%3Dsearch%26viewlocale%3Den_US&productCode=&answerid=16777217&searchid=1397780403561 .
    After installing this, you need to reset the photoconductor counter.
    With the printer on, open the front cover and press and hold Stop for 5+ seconds. When you see Resetting PC Counter release the Stop button. Close the front cover when prompted to do so.
    If this doesn't clear the error, try powering off the printer for 10 seconds. Otherwise, try unplugging the printer for a minute to reset the internal memory. If the unit still doesn't reset the counter, it may need service. Contact Lexmark.
    I hope this helps.
    Apr 17, 2014 | Lexmark X342n All-In-One Laser Printer
    Grinding noise
    could be the laser unit on top of the printer out of whack -i have the same fault also
    Jun 29, 2012 | Lexmark E120n Laser Printer
    Orange light is constantly flickering. I have put a new toner cartridge and now a new photoconductor kit in and it is still flashing
    Please make sure to reset the printers' pc count. Below are the steps.
    1. open the front cover. Leave the printer powered on. 2. With the front cover open, press and hold the stop/cancel (pattlnk_392009_184-e260%20stop%20button.gif) button. 3. Eventually all of the lights will begin flashing, indicating that the photoconductor page count has reset. When you see this light sequence, let go of the pattlnk_392009_184-e260%20stop%20button.gif button. 4. Close the front cover.
    If you wish to confirm that the photoconductor page count has reset, print a menu settings page.
    Jul 11, 2011 | Lexmark E260dn Laser Printer
    How do you reset the photoconductor counter on the lexmark e260dn? the light is blinking yellow right after i replaced the toner cartridge. Have put this printer through a lot of use over the last 3/4 of...
    1.open the front cover. Leave the printer powered on. 2. With the front cover open, press and hold the stop/cancel (X) button. 3. Eventually all of the lights will begin flashing, indicating that the photoconductor page count has reset. When you see this light sequence, let go of the X button.
    NOTE: If you wish to confirm that the photoconductor page count has reset, print a menu settings page.
    Jul 09, 2011 | Lexmark E260dn Laser Printer
    We changed the toner cartridge and the toner light keeps blinking..
    Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced
    Jun 14, 2011 | Lexmark E260dn Laser Printer
    Lexmark E260dn toner light is still on after changing the toner cartridge
    Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
    If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
    For further assistance, please call Lexmark Technical Support.
    Apr 12, 2011 | Lexmark E260dn Laser Printer
    Replaced toner and maintenance kit -keep getting yellow lights on exclamation and toner
    If the toner and the exclamation lights are blinking yellow after replacing the toner and maintenance kit, then you will need to reset the photoconductor counter. But if the exclamation and the toner lights are steady on yellow, then that means there is something wrong with the toner.
    Jul 27, 2010 | Lexmark E260dn Laser Printer
    Lexmark C510 is making grinding noises while printing large jobs
    I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
    Oct 15, 2009 | Lexmark C510 Laser Printer
    Lexmark E260 Laser Printer Logo
    819 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
