Question about Toshiba Satellite L355-S7811 Notebook
Data dump forced shutdown repeastedly, now only works in safe mode I think I need to re-format
  • 69 Answers
Yes you will nedd to re-format your laptop,
but you can try one thing
- Disk Defragmentation
if this also dont work than last option is re-format
thanks
Posted on Dec 30, 2010
Stuck in sleep mode
Hold the power button down until it is fully shutdown. Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can't do the download on your machine, do it on a friend's, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found.
Jul 14, 2014 | Computers & Internet
What does starting in safe mode acconplish?
Booting in safe mode simply launches the operating system with minimal services enabled, usually no network availability, and a limited ability of usage, safe mode is used when diagnosing possible threats or for emergncy data access. In the event that the computer has stopped you from gaining access to it. A computer should never forcefully start in safe mode, it is an option usually selected on a black and white screen, start normally or start in safe mode, or start in safe mode with network. Hope this explains is a little better
Jun 14, 2014 | Microsoft Windows 7 Home Premium Operating...
Blue screen appears & keep restarting
It is possible that the malware is to blame, in which case a computer technician will need to sort it out.
I think it may be a bad memory module or loose memory module connection.
Take care!
damnor01
Apr 28, 2012 | Acer Extensa Computers & Internet
How do you get to safe mode for toshiba
Debra,
There are a couple of methods to get to Safe Mode on a PC.
The first and established method of getting Safe Mode to pull up is to turn the computer off all of the way. Then turn the computer back on and immediately start tapping the F8 key on the keyboard. (Don't hold the key down, but instead press it over and over.) This should bring you to a Safe Mode menu to choose which option to boot into.
If you have pressed the F8 key and the computer still attempts to boot to regular windows, you can press and hold in the power button to turn the computer off and retry the F8 option.
The other, less established method of forcing a computer into safe mode is to turn the computer on, wait until you see the Windows logo start to load, and then press and hold in the power button to force a shutdown. Doing this twice in a row should result in the safe mode prompt on the third boot up attempt.
Hope this info helps!
Nov 30, 2011 | Toshiba Computers & Internet
My laptop get restart in an intervals or get hang ...
This will occur if the Windows files are Corrupted or Fragmented, the solution is to backup by logging in to Safe Mode. Please restart the computer and try pressing F8 Key to select Safe Mode. If the Safe Mode is working fine then please backup the data and Format the computer using the Window XP or the Operating System Disc which you have. If the Safe Mode is not working then use any Linux CD like Ubuntu (www.ubuntu.com) it's free! Then boot the CD to backup the data for any external Hard Drive or Pen Drive and format the Notebook using the appropriate Operating System Disc like Windows XP, Vista, or Windows 7.
Mar 26, 2011 | Toshiba Satellite Pro L300 Notebook
I need to reset ... it will only go to a blue screen . Saying crash dump
To solve this issue boot your system to safe mode. Restart your computer and press F8 while booting a select Safe mode option. Once it logged in to safe mode, Go to start -> RUN and Type msconfig. So you will get a window. You need to click on START UP tab and search for DUMP or any files with DUMP phrase.Once you found it uncheck the entry and Click on APPLY and OK. Restart your system normally.Now you can see your system working fine. see the pic below
Dec 05, 2010 | Acer Aspire Z5600 PC Desktop
Dell inspiron 1525 memory test failure
Were you able to do a virus scan
try to get on in safe mode by constantly pressing F8 during restar select safemode
See if shutsdown in safemode
Do you here the fans running when it's on
You may just need to do a restore
Let me know what happens in safe mode
Jan 19, 2009 | Dell Inspiron 1525 Laptop Jet Black
Blocking .exe files and not able run windows in safe mode
I would recomend you to download Malwarebytes, install it and then run it
you can install it from http://www.malwarebytes.org/mbam.php
or else i can take a remote of your system and can fix it,
www.crossloop.com/dellcertified
Dec 11, 2008 | Mcafee Downloadable VirusScan Plus 2008 -...
I Have tried To Install Windows Vista on my pc which was on it before. The installation gets all the way to the completing part then just restarts and then has the screen your computer was not properly...
OK ya got a problem... here is what to do... boot up on the DVD then get to the part where ya choosing ya Drive Etc, and FORMAT the entire drive/partition ... you will loose any/all data at this stage... after ya format ya drive... NTFS.. Then install vista...
If that will not work get a formatting program from the Drives manufacturer, or Partition Magic, or the like, and boot up on it CD/DVD, Floppy, whatever and then Format the Drive... NTFS Then install Vista...
Jul 15, 2008 | Computers & Internet
Unwanted Auto Shut-down & subsequent hard drive crash
hi there
you have two solution available first option is installing windows xp by xp cd put the cd in cd drive and boot from it and choose to install windows on the c drive the same drive that has your old widows but you have to choose not to format the partition which will ask you to delet the windows folder and reinstall it BUT   !!!!!!!!!!    you have to be carfule with this option  dont choose to format the partion you have to choose keep the partion otherwise you will loose the data
secound option is to open the the pc case df04459.jpg and take out the hard drive dff18f3.jpgand then connect the hard drive to another pc by usb ide cable 645e5c7.jpg53f2c49.jpgtake all data you need and save it
Oct 24, 2007 | Dell XPS 200 PC Desktop
Toshiba Satellite L355-S7811 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
