Question about Springfield Wireless Rain Gauge Thermometer
Have a Springfield 6837 and cannot get it to reset for outside temp after changing batteries
I have a Springfield precise temp base station 433mhz wireless It has 11 buttons on front no number. It came with outside temp and weathervane parts. Would you have a manual for it? Thank you Jackie
Hi, Jackie.
Is it look like this ?
With Windspeed and 3 station temperature reading ?
If so, model number is 91751
Good luck with finding Manual.
I have paper manual with me, I can scan most useful pages for you (Buttons)
Apr 06, 2015 | Springfield Measuring Tools & Sensors
Springfield precise temp # 91455 reads LL.L on the outside temp gauge.
"L" is probly for low... try replacing the sensor component
Sep 19, 2013 | Computers & Internet
I have a Springfield precisetemp 433 wireless. The outside temp is reading 99 degrees when it should be reading about 70. When I disconnect the unit from the probe the temp is correct, so I'm guessing...
SOMETIMES WHEN METAL IS IN DIRECT SUNLIGHT IT WILL
GIVE FALSE READING. MY OUTDOOR THERMOMETER IS METAL AND IT READS ABOUT 15 DEGREES HOTTER THEN IT IS. BECAUSE IT'S IN DIRECT SUNLIGHT.
Sep 18, 2013 | Springfield Measuring Tools & Sensors
Springfield precise temp instructions
The outside temp for the inside reading quit working this morning when I went to check the temp.The outside sensor was working fine.
What do I do to get the inside one to work again. The other features were working fine.
Jun 17, 2013 | Computers & Internet
Instructions for springfield precise temp model 91455
I also reset my 91455 today. Go online to Springfield precise temp manual 91455
May 29, 2012 | Springfield 91455 Wireless Digital Outdoor...
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Springfield Wireless Rain Gauge Thermometer Logo
268 people viewed this question
Top Springfield Measuring Tools & Sensors Experts
ray gallant
Tom Chichester
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
