Question about Electrical Supplies
I have an aldi powercraft generator pc3200dv/10 i can start it but it cuts out after a few minutes ,i am finfding it hard to find the fuel valve also it runs for the few minues with choke on but if you turn the choke off it stalls. can you help me.
Hi there, YES manual VERY misleading, starting it all revolves around the Choke, if I remember correctly, place lever on Choke, start then move lever to on position, good luck
Posted on Jan 26, 2011
  • roger195 Feb 25, 2011
    The choke lever is labeled incorectly! Start the engine with the choke lever in the 'OFF' position then after a few seconds move the lever to 'ON'. My PC3200 is not fitted with a fuel valve either.
    Roger
My Garden line ,Aldi lawnmower isnt running well. It is smoking, running slowly,back firing and, using lots of fuel.I have changed the oil and the fuel to no effect. can you help?
if it isnt the spark plug
is this the same aldi mower
Gardening with Rik unboxing and review of the Gardenline Aldi lawnmower
how much work has it done
did you tip the mower over the wrong way and oil got into the valve cover or carby
the carby is a metal bowl with a 10 mm drain nut
undo that see if fuel is clean and flowing
best bet is it needs a carby clean or throttle cable adjustment
maybe even a govenor adjustment
Mar 26, 2017 | Garden
Turn on fuel cock, motor starts, after a few minutes gas starts flowing out of the carb at the air filter
The needle valve on the carbureator float is stuck open or has a little debris stuck in it. You will have to take the bowl off and clean out the seat for the needel valve. A Qtip or small wooden dowel works best.
Dec 07, 2013 | Briggs Stratton H7159 & Stratton® 5500,...
Generator
I suggest that the rings are now soft or broken and not sealing or the valves are stuck open unless it is a 2 stroke. Gen sets have a low oil cut out switch that stops the motor immediately there is insufficient oil in the sump. I wonder why it allowed you to run the engine for 10 minutes as it will not even allow you to start with no oil.
Jun 07, 2013 | Electrical Supplies
Fuel leak on powercraft 720 generator
The fuel hoses can leak if bent in an unreasonable fashion during installation or upon completion of installation.
Oct 04, 2012 | Office Equipment & Supplies
My generator is a briggs and stratton 7kw prowered. connected to full propane tanks. i have not had any problems with the generator until this past weekend. the generator starts up fine, and then once...
You have a fuel delivery issue that can be dealt with by cleaning carb or replacing it. If you do replace carb has to be adjusted to the motor.(idle, mixture)
Sep 03, 2017 | Briggs & Stratton Briggs Stratton 7 kW...
Poulan WT usually starts Ok but after it is used for 8-10 minutes it cuts out when when trigger is released. Happens mostly when you're cutting & then release trigger when cut is done.
If the carb hasn't been rebuilt in a few years, often the fuel pump diaphram gets weak or the little flap check valves get deteriorated. Carb kits are about $20.
Feb 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
98 Honda Valkyrie Tourer, engine stalls after riding for a few miles. Engine will turn over after stalling, just no spark. After sitting for 10 minutes, engine fires and runs for a few minutes and stalls...
Check vacuum line from #6 intake runner (port side rear cylinder) to the fuel petcock valve. The valve is vacuum operated for safety. It cuts off fuel to the carbs when the engine is shutdown. Hose could be cracked or diaphram in valve is cracked. Easy to inspect the valve.
Apr 19, 2009 | 1998 Honda F6 C Valkyrie
Cuts out after 10 minutes
Sounds like fuel tank vent problem , air has to get into tank
sometimes its vented by fuel cap but a lot of hedge trimmers use
a duck bill valve right thru tank or hooked to hose .
To test if this might be the problem loosen gas cap when it starts to die .
good luck
Jan 20, 2009 | Garden
Electrical Supplies Logo
1,439 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
