Bearings are bad in the heater motor.Need price on parts
  • 102 Answers
I need make model and serial number off unit. Heater motor can you specify a little better as to which motor it is? is it hooked to 4in round steel pipe or the main blower motor that circulates air through the structure
Posted on Dec 30, 2010
I have a hanging Perless gas heater in my garage. The burner lights but when the fan does not com on when it gets to tempeture and it shuts down. If I manually start the fan it will run but has stopped...
the fan motor berings seem bad. since peerless parts are extremely hard to find now, see if you can lube up the bearings with 3-in-1 oil . if they are oilless, you'll have to replace the whole motor. if you check the specs on the motor housing, grainger.com could probably find a decent replacement for you
Mar 01, 2014 | Mr. Heater Heating & Cooling
Mr heater fan starting to make noise when starting
try taking apart fan housing & look to see if fan blade is scraping the housing. next look to see if fan blade is secure to fan motor shaft.next look to see if fan motor bearings are worn egg shaped and try oiling fan motor bearings with sae 30.
somewheres amoung all this inspecting of the fan motor, you will find the cause of the problem and learn what new parts you may need to buy to fix it.
Jan 17, 2013 | Mr. Heater Big Buddy Heater
Looking for a Mastercraft table saw motor, part number OQEF
Sears has raised the price on that motor. It's $162.99 now. There is a 99% chance that you really only need new bearings, not the whole motor. They fail regularly in smoky, noisy, horrible manner. You can buy a better quality bearing here: http://www.vxb.com/page/bearings/PROD/6200-2RS10-1. The original ZZ bearing is a "shielded" bearing. These RS replacements are "sealed". The difference means sawdust powder no longer gets trapped under the shield to destroy the bearings.
Apr 04, 2012 | Saws
Pump started to make a rattling noise after 4 yes of perfect operation.
Pull off the pump and clean it out.
The noise could be sediment build up causing pump rotor to make noise.
Noise could also be bad bearing or bad rotor.
Noise could be air bubbles in the line.
Once pump motor begins to slow, no mater what the cause, it overheats and begins to burn out.
Many times, once a motor has slowed, it never recovers and spirals downhill and stops working.
There are no repair parts for recirculation pumps.
Following page has general information plus links to Grundfos manuals, installation, and contact.
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 05, 2011 | Grundfos UP10-16B5/ATLC Comfort Series...
I have a miller furnacefor 10 years now last year i had to replace the blower motor . Now 1 year 1 month later the motor is makeing a squielee noise. i called the ele. supply Co. i got it from he just...
The bearings are bad. No need to keep oiling them. You're going to have to replace the motor. We get a bad one like that too from time to time. Just take your lumps and change it out, Chances are you wont have to deal with it for many many more years to come. Sorry about your bad luck.
Jan 26, 2011 | Heating & Cooling
Fan does not blow. Believe we need a new fan motor.
Have you considered checking to see if the fan motor might just need cleaning and lubricating?
Most small fans and heaters, have small fan motors, in which the bearings have dried out over the years. If you have made an electrical check on the motor leads-- and you have electric going into the windings, likely the motor feels warm? (If not-- possibly a bad splice where the supply wire attaches to the tiny armature wires?-- check , and check continuity)
If you want to tear into the fan motor, and clean up and lubricate the bearings-- here are some tips:
First you need to get inside the heater of the fan housing-- by removing the protective covers.
Note the screws, sizes, locations, and how the protective covers will go back on when you are ready to reassembly-- Mark where the screw holes are that line up with the matching other parts.
Then remove the motor from it's bracket (Possibly have to remove the fan first?)
You will have to remove the fan, to lubricate both front and real bearings.
Next you will need to remove the 4 long screws that hold the motor frame together-- Be sure to mark the original alignment, so you can reassembly correctly.
Now, with the fan removed, gently separate the Front and rear half's of the motor. Usually the windings will stay with the portion of the motor wher the wires are still attached. Either way, you are going to have to get the bearings to slide off both Shafts of the armature-- without breaking the delicate winding wires-- the wires are hair thin on small motors!
Now clean up the caked on residue on the shaft where the bearings ride, with rubbing alcohol. Clean up the internals of the bearings as best you can- making sure the pores of the oil-lite bearings are not plugged with solids. Now begin the gentle process of getting the bearing wicking to soak up new oil. When you are sure the reservoirs are well saturated, then generously lubricate the shafts, and slip them thru the bearings again-- retracing all your steps above, The motor shaft should turn freely now. You can test the motor without the fan on-- to be sure you have the motor itself reassembled properly.
Double check all the splices, switches, and any high temperature limit switches for continuity-- and trace the wiring all the way back out thru the power supply cord.
What did you find, and what do you need to do next?
Let us know--
Mack B
Jan 23, 2011 | Lakewood 798240 Utility Heater
Fan make noise
Fans, like wheels have bearings. The bearing are probably wore out, and loose now. You can pick up a fan for this at a junk yard for cheaper than a brand new one - price new one as well though just as a safe measure and for comparison purposes.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 14, 2010 | 2008 Jeep Liberty
Mortor berrings
Grainger had a wide variety of bearings ... usually, they have a price spread for bearings depending on the quality of the bearing. I just ordered a $10.00 bearing for my $50.00 sander. They offered the same size bearing from another manaufacturer for $75.00. I didnt buy that one.
Good luck with your repair.
Mar 03, 2010 | Heating & Cooling
Reddy 110000 btu fan motor needs front bearing , shaft id fine i took motor apart by grinding weld off of end bell. i am a motor repair expert, retired do not have accses to a lathe or i coud make a...
You may want to contact Master Parts, they may not have the bearings. However, they may have that motor at a reasonable price. You can contact them at 800-446-1446 or online at www.masterparts.net. I hope this helps you.
Mar 06, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
H1001d stopped working
You might have the blower wired incorrectly or a bad blower. Also make sure the hose is connected to the blower and pressure switch.
Dec 07, 2008 | Hayward H Series Induced Draft Abg 100,000...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
