Question about Brother DCP 7010 Multifunction Laser Copier
When coping a black line approx. 2cm wide is appearing down the side of the copy no matter what size is copied
    Problem Solver:
  • 6 Answers
Check your drum unit. There is a blue or green plastic part, that includes a whidepad. This pad is neccecary to clean the corona wire in the drum unit. Maybe you have to move the plastic part to the other side of the drum unit...
Posted on Jan 01, 2011
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
Line appears on copies from top to bottom of the sheet, Approx 7 7/8 in. It happen both off the glass and when ripping a job to machine
With lines showing up with both coping & printing, you are most likely need a general cleaning and if that will not work, odds are you are going to need a new OPC drum & drum cleaning blade and a new developer change..... Good Luck
Nov 09, 2012 | Xerox 8830 AccXES N5T Wide Format Digital...
Solid black line appearing on right hand margin approx 1.8cms wide , how can i sort this please
please specify model no. of the machine & black line comes when u receive faxes or when u copy ? please let me know then i'll be able to provide solution. Thanks
Aug 24, 2009 | Brother Office Equipment & Supplies
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
1/2 inch wide black line appears on the copies
Please use the link provided below to download the user guide. The user guide and the troubleshooting guide will have detailed steps to solve this issue.
http://safemanuals.com/user-guide-instructions-owner-manual/HP/PSC%201510-_E
May 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Copies
Hey :), I'd be happy to help. To make a copy you must lift the lid and lay down the item you want copied. And then on the side of the printer you will see a line of buttons , to copy the item you want,you have to let the printer know if you want the copy to be in black and white or color .To let the printer know of you want the copy to be in black and white or color, you have to select/press between the black ( black and white ) button in the line of buttons or the color button. Once you press wither of these buttons/options , the printer will automatically start the coping process. thanks! I hope this helps :)
Oct 11, 2008 | HP PSC 1315 All-In-One InkJet Printer
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Why do I get a line of faint or no copying on the page?
Does this blank line run top-to-bottom or side-to-side, and which direction is the paper traveling through the machine, portrait or landscape?
Jun 03, 2007 | Minolta EP1031/1031F CS/PRO Copier
Brother DCP 7010 Multifunction Laser Copier Logo
162 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
