Rca m50wh92s dlp projection tv
Works perfect when turned on but after about a minute the screen goes black but the sound is working fine. it repeats this..... the picture is perfect when on so i dont think its the lamp. other people have this problem but nobody seems to be able to find an answer. they deleted my warranty because i cant find my reciept.....man this tv is only 6 months old!!!
  • paullseese Jan 20, 2009
    i have the same problem mine is about 9 months old and i'm going to try to get the bulb replaced before i do anything else like take it to a repair service
  • rpky Feb 26, 2009
    I got the same problem do you think it needs a new bulb, mine is also 6 months old, i don't have the reciept but I have my credit card statement reciept, I purchase this at wallmart, any help would be appreciated..
    please reply to: rpky@hotmail.com
It is the lamp...easy fix
Posted on Jan 06, 2010
I have an RCA M50WH92S and when i turn it on the power light flashes 5 times and no picture. I have replaced the bulb today. any ideas?
first is parts for this set can get expensive---I would do two things first:
1. Look to see if lamp comes on at all--even for a few seconds.
2. Look with lamp removed where it faces to see if color wheel broken/shattered or missing pieces of the wheel.
If the lamp does not come on the next suspect would be the Ballast which powers the lamp---if its bad you may or may not get sound either.
Dec 09, 2012 | RCA M50WH92S Bulb
Why does my screen go black
The set is shutting down the CRts for protection which is almost always a vertical deflection failure with that chassis if the audio still remains working when the pic drops out. Replacing the deflection board should solve the issue. You can get the ITC222A deflection board PSB260 from www.tvrepairworld.com
Mar 24, 2012 | RCA R56WH76 Projection Television
RCA M50WH92S PICTURE COMES ON FOR ABOUT TEN
Replace your LAMP if all of your Fans are running! If lamp fan is not running Lamp will not turn on .Call FOX for Lamp 1-800-227-5369
Jun 20, 2011 | RCA Televison & Video
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Samsung DLP Problems
Possibly thermal sensor,ballast,or the lamp or all of the above,or the main pcb could be the culprit
Dec 12, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
341 people viewed this question
Top Televison & Video Experts
