Cell Phones Logo
Posted on Dec 30, 2010
My bluetooth wont work. it wont let me put my visibility on but the whole touch screen works. it just wont let me click on for the visibility
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Dec 30, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
4989
Points
26
Restored your phone
3answers
My bluetooth wont pair with other phones
change the setting of bluetooth
May 01, 2010 • Cell Phones
1helpful
2answers
My mobile bluetooth not working properly and not sharing data with another mobile
hi visiter
if your mobile phone blue tooth not working, plesse visit the servise senter and update the mobile software,
Motorola V9M flip phone will not connect with ipod touch 64gb?
your bluetooth "phone visiblity" must be set on "shown to all", you will sure find such an option in your bluetooth menu
1helpful
How do I enable bluetooth on my gps? the bluetooth is not in settings
it will only work if bluetooth is in your unit which is the 1310, and 1370 the 1300 and 1340 does not, if you have go to main screen and then settings scroll down and you will find the Bluetooh logo, press and enter, then "add device" have your phone on "visible" in the connection/bluetooth screen or gps wont find it, when they match one will ask for password, so read alll the screens as they appear as it will be supplied
1helpful
I want to transfer a photo from htc viva to another mobile by bluetooth
hi Mostafa
first go to connections
activate the bluetooth
then go to menu on the right bottom and click on bluetooth
then select the second tab 'MODE' here tick the check box about visibility
click ok and come back no in this screen click on the search for new device (BT on the other device should on and device be visible) and once it searches seclect the pairing and send the file
cheers
pls rate if this was any help
1helpful
2answers
The bluetooth on my htc viva is not working
Click Start
Select Programs
Then Click Comm Manager
Turn on Bluetooth
See Right Bottom - Click on Setting Select Bluetooth
Add New device
Select <other bluetooth device>
Insert some code to connect.
Done.
Lg vu
User must be logged in as Administrator or have administrator privileges to modify system files
Setting up the handset
1. On the handset, touch the Menu icon located in the lower left corner of the main screen.
2. Touch the Settings icon located on the bottom of the menu tabs.
3. Touch the Bluetooth icon.
4. Touch Turn On.
5. Touch Settings.
6. Touch My Device Visibility.
7. Touch to select On.
8. Touch Set.
Setting up the connection
1. On the PC, double click the My Bluetooth Places icon on the desktop.
2. Click View devices in range.
3. If the handset does not appear, click Search for devices in range.
4. Right click the icon representing the handset and click Pair Device.
5. Type a numerical pin code (example: 1234) in the Bluetooth PIN Code field and then click OK.
6. On the handset, an Accept? prompt will appear, touch Yes.
7. Type the same Bluetooth passcode (Bluetooth PIN Code) entered on the PC and touch OK.
8. On the PC, return to My Bluetooth Places.
9. Right click the icon representing the handset and click Discover Available Services.
10. Double click the Dial-up networking icon.
11. When the connection window opens, click Cancel.
12. Click Start, Settings, Control Panel and double click Phone and Modem Options.
13. Click the Modems tab.
14. Click to select Bluetooth Modem and click Properties.
15. Click the Advanced tab.
16. Type at+cgdcont=1,"IP","isp.cingular" in the Extra initialization commands field.
17. Click OK.
Making the connection
3. Right click the icon representing the handset and click Discover Available Services.
4. Double click the Dial-up networking icon.
5. Type [email protected] in the User name field.
6. Type CINGULAR1 in the Password field.
7. In the Dial field, type *99#.
8. Click Dial.
You will now be connected to the AT&T data service
NOTE: I had to change every instance of "isp" to "wap" for this to work (including the Advanced Settings Tab), but y'all might not have to. Hope this helps.
1helpful
3answers
HTC P3400i LCD Problem
My Htc p3400i phone can't share fast informnation via Bluetooth
2answers
Bluetooth wont work
Goto:
spanner - wheel click!
bluetooth -wheel click!
bluetooth disabled - wheel click!
Enable bluetooth -wheel click!
Paired devices
*EMPTY*
- wheel click!
Add device - wheel click!
after the search select the device you wish to connect to...& contiue to follow the on screen prompts & pairing instructions.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
