Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
I have a madcatz bluetooth headset and when i plug it into the ps3 or my pc all that happens is the light turns red for like 3 seconds thn shuts off. i can sometimes hear some beeps if i put it next to my ear and i already returned it for a new 1 and have the same problem. It just wont charge or turn on and its brand new not even 1 day old.
This only means its Charging, read the instructions manual
Posted on Mar 03, 2011
  • larsonbrett Nov 03, 2011
    How do I no when it's done charging
So i bought the Mad Catz 8860 model, the black and silver one. i went home used it, worked fine... a couple months passed since i used it, i went back to play with it and its not working. i plug it in to...
Hi Matthew,
With those headsets that think is a known issue.
If nothing happens when you hold down the answer button then the battery must be out (or the headset is faulty).
If you tried to plug it into a USB on a PC to charge it, and the red light does not stay on then I'm afraid it became faulty.
All you can do now is to get back to the retailer who sold it to you and get a replacement for it, or if the retailer cannot help you consider getting back to MadCatz requesting a replacement if it's still within warranty.
Hope it helps.
Apr 07, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
My brand new madcatz bluetooth headset wont charge, when plugged in the charging light is red, but it increases/ decreases in brightness after 4 hours it will not turn on or sync. This is the second one...
i just got mine and it when i plug it in to charge the red light turns on for like 10 seconds then turns off and it wont turn on so itss dead... return it?
Aug 29, 2010 | Mad Catz Bluetooth Headset for PS3
I just bought my madcatz headset from the shop. Charged it for 4 hours and the red LED turned off so I suppose it is charged. Then i go to the “Manage Bluetooth® Devices.” and go to the screen where...
The power button is not the right button to press.
Here is the steps I take:
1. Power on the headset
2. Have PS3 scan for new devices
3. Hit the tiny button that is next to the volume buttons on the top of the headset.
4. PS3 should recognize "8860" and ask for a passkey which is "0000" by default
5. Paired and ready to go
Aug 26, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do you get the ps3 to pick up the blue tooth head set
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be ‘paired’ so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the “Settings” menu, press X on “Accessory Settings.”
3. Press X on the icon labeled: “Manage Bluetooth® Devices.”
4. Scroll down and press X on the icon labeled: “Register New Device.”
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset’s LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on “Start Scanning.”
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate “8860” from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: “Register completed”
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Source: www.madcatz.com/faq
Aug 11, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Mine wont turn on
Hello, did you check the battery? Tu get the full charge, the headset red light must stay steady on. If you get it charged you can pair it: hold power button till the two leds blinks, now scan for bluetooth from PS3 and choose your mic setting. Other than that I'd call madcatz technical support. Good luck, Peter_Rei
Aug 04, 2010 | Mad Catz Bluetooth Headset for PS3
My Bluetooth set is plugged in but will not show up to add
Try to put your headset in pairing mode first. Press and hold the K1 button for some 8 seconds, until the indicator led is rapidly flashing alternately in red and blue. Then, make your PC's bluetooth application search for new devices. Your headset should appear. Select it make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done just once. After any 2 devices are paired, they should connect to each other just by being next to each other (provided their bluetooth radios are turned on, of course). Othewise, a simple press on the button should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 28, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
My headset from madcatz wont do anything
I may be able to help you.
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Dec 28, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
The red light indicator says it's charging, but it isn't.
idk that happen to me too buht my blue toooth i just baught a gamestop madcatz .. and on the instruckstions sheeet it says if its charging it;ll turn red . buht myne turn red for like 3 sec then it disapeares .... :O
Jul 10, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Can't pair bluetooth
....My madcatz bluetooth will not charge everytime i plug it in the ps3 the red light comes on then it goes off and it keeps on doing it and its a brand new bluetooth...i hold it for a long time and it still wont work..HELP PLEASE!!!!!!1
Feb 06, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
490 people viewed this question
Top Mad Catz Radio Communications Experts
TO Lady
Michael Vincent Cruz
Bill Boyd
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
