Want to know if i can do a spin without wash and what the sign is
  • Washing Mach... Master
  • 19,396 Answers
Hi Kat.
If the unit is a washer-dryer you surely can perform stand alone spin cycle. Most washers also allow spin only cycle. In older models spin only may sometimes only be performed by advancing the timer knob to spin part of the cycle.
Please provide info on washer make and model to know more.
Regards.
Ginko.
Posted on Dec 30, 2010
My washing machine only spins on the normal cycle, no spin at all on the gentle cycle. What do I need to replace?
your motor of ur washing machine have some problem , i hope so u go to a washing machine or manufacturer feed
Oct 14, 2014 | Washing Machines
Kenmore 90 Series washer, won't spin, just loud roar in spin cycle
This site was very helpful to determine problems I had and they have the repair parts. http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair-Help
Washing Machine Repair Help
Apr 28, 2014 | Kenmore Washing Machines
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
GE WHDSR315DAWW Washer. The drum spins. The water drains. Agitator will not agitate. Help.
Normally the sign of a failed transmission - last time I bothered to buy one it was >$130 without service charge.
Feb 27, 2011 | Washing Machines
Kenmore 80 series washing machine model stopped spinning
Check this out acc8ce4.jpgmight be a partially defective coupling or lid switch. More HERE
Mar 21, 2010 | Kenmore Washing Machines
I need the user manual for my lg tromm wm2277hw because I don't know how to get it to spin without going through the whole wash cycle
for a drain and spin : turn unit on hit spin Button 1 time then start/pause button
this a drain and spin only..
Jun 15, 2009 | LG WM-2277HW Front Load Washer
CLOTHES STILL WET AFTER SPIN CYCLE
Dear dgloss1856, Sun 4-12-2009 1:14PM EST USA
Washers will shut down automatically without completing the spin cycle for two reasons.
1) Too many clothes in the washer at once (overloading with clothes) !
2) Too much soap in the washer when washing!
When this happens you should restart the machine in the spin cycle or if you can't start in spin run a full cycle without adding soap.
If this doesn't solve the problem you may need to clean the timer or control circuits depending on your machine by cleaning with electronic spray cleaner (available at Radio Shack) by spraying the timer or control circuits as instructed on the can of electronic cleaner.
cd1ee64.jpgLet me know if I can be of further assistance!
Apr 12, 2009 | Washing Machines
Does wash clothes
depending on what washer u have this could be a sign that your carbon brushes are on there last legs not much to replace them but need to know what make off washer it is hun peter
May 27, 2008 | Washing Machines
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Aug 01, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
