Question about Sony STR-DE185 Receiver
The tuner reads protect when volume is at 47 with no wires attached. Will go no higher than 29 with wires attached.
    Brigadier General:
  • 8,546 Answers
I'd say it has a mysterious internal problem that would require a hands-on tech to take a look.
Posted on Dec 30, 2010
Receiver channel volume not identical
Remote controls normally do not adjust stereo volume levels independently, and I will assume that the problem is present on ALL input settings (tuner, CD, etc.). Check "balance" control settings, speakers and speaker wires for possible problems. Balance control at 12:00? Inspecting speaker wires and speakers do not reveal problems? Have you swapped speakers to see if problem reverses? Try this "process of elimination" and hopefully you'll ID the problem.
Mar 23, 2015 | Yamaha Remote Control RXV496RDS...
Sony HCD-GT222 Hi-Fi CD and cassette deck with tuner, suddenly started to shut itself down at volumes higher than 50%, after three years of flawless operation.
It's thermal; protection is happening probably due to bad ventilation. Fuzz and dust can block air vents.These need to be vacuumed out now and then.
Jan 22, 2014 | Audio Players & Recorders
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
THE VOLUME DIAL (LARGE ROUND WHEEL) DOES NOT WORK PROPERLY. You turn it clockwise to get higher volume, the digital numbers go lower, higher, and not the way it should be. The volume doesn't increase or...
Some tuners denote volume as attenuation so zero means it is at full volume and -20 means it is 20 decibels or 20 percent etc below zero. Essentially, zero means it is not being held back while the higher the number, the higher amount of holding back.
I am not sure what you mean by the volume does not increase or decrease normally so you'll have to ask that one with more details and information to get something more on that issue.
Jan 17, 2018 | Sony CMT-HPX9 CD Shelf System
I cant use my samsung DVD player is showing protection.Please help me to repair it.
this just happend to me today. check the wiring going into the reciever it wouldnt let me go over volume "29" i checked the back saw my mistake, fixed it and it was fine. hopefully this helped
Apr 03, 2010 | Samsung HT-DB600 System
Stereo cutting off when volume is over 29
Twenty nine sounds pretty loud to me. A shorted voice coil in any one of your speakers will drop its resistance value so if the amplifier thinks its feeding a short circuit, will "protect" itself by shutting off. Check wiring carefully and each speaker at a little lower volume for sounds of distortion ie: shorted voice coils...
Jun 27, 2009 | Kenwood Marine Receivr/Speaker CD/MP3/WMA...
My system shot down during a movie
The reason why your receiver is going in protect is because there is a short circuit happening. This would either be on your speaker wires, speakers or receiver itself. What you want to do to check would be:
1. Unhook all sources and speakers from your receiver.
2. Turn on your receiver and crank up the volume to maximum, if your receiver does not shutdown or go on protect then the receiver is OK. If it does shutdown and go on protect then its an internal problem on the receiver and you would need to send that over to an authorized service center.
3. Hook up a source and 1 speaker. Play something from the source or the fm tuner, Crank Up the volume to about 46 or 47 volume. If the receiver does not shutdown, its good.
4. Hook up a second speaker and repeat the process until you encounter the pop and shut down
if for example you encounter the pop on the 4th speaker, try changing the speaker wires.
5. If the receiver still shuts down then it would be a short on the speaker itself and it would need to go to an authorized service center.
Feb 23, 2009 | Onkyo HT-SR800 System
Receiver shuts off when volume raised above 10
A fuse breaker or resetting electronic componet device attaced to the audio receiver protects the amp & speakers for destruction! The quality of the amp ,spkers& spks. wires help on choosing for protection shut downs! Of course at 10 volume you risk all of the amp in the receiver , buy a higher quality brand reciever ,intergrated amp, single amp . BE CAREFUL AT THE HIGHER VOLUME RATINGS YOU RISK HEARING DAMAGE! FOR REAL!
Feb 04, 2009 | Philips FR975 Receiver
Amp switches off at about -10db volume level
I suppose that on all speakers connections + (positive) is on +, and - (negative) is on - ?
Oct 08, 2007 | Yamaha HTR-5830 Receiver
Sony STR-DE185 Receiver Logo
141 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
