How do I CHANGE A WICK IN A HNHC2230 KEROSENE HEATER
    Problem Solver:
  • 6 Answers
Go to page 8 in pdf manual that is attached. It will show you precisely how to change the wick in your heater. Be sure to follow safety precautions exactly for your protection.
http://www.sengokula.com/sites/default/files/manuals/convectionheaters.pdf
Posted on Dec 30, 2010
How do replace the wick in a turco kerosene heater
This a very odd question about cell phones, isn't it? There are two videos on you tube to help you do this.
Kerosene Heater Wick Replace - YouTube
How To Replace a Kerosene Heater Wick Tutorial - YouTube
Jan 26, 2014 | Lands Phones
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
Is it true that if you use moth balls with the fuel in my kerosene heater it burns cleaner & there wont be any build up on the wick? I get alot of soot build up on the wick of my kerosene heater &...
I can't answer about moth balls cleaning the wick but off the top of my head I would not try it as I do not know just what gases your unit would give off. I use kerosene heaters and find that after about 5 tanks of fuel I put on a pair of household rubber gloves, remove the chimney and turn the wick all the way up. Then I roll the wick between my fingers and get the hard carbon off. Once I have the wick clean I use the shop vac to vacuum it all up. I have found that by doing this my wick is never dirty, I do not get any smoke and the wicks last more than 20 years. Probably a better idea than moth balls. Let me know how you make out.
hardrocko
Feb 09, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Portable kerozene heater
If this is a forced air kerosene heater it does not use a wick. If it is a portable wick heater you can get them for all brands at Portable Heater Parts on the web.
Apr 02, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
I need to change the wick on my dk 23 corona kerosene heater
what make and model is it? They are very simple to change,never heard of 1 "Not" lighting tho,unless you have water in tank and the wick sucked up the water...water don't burn,You can also raise the wick in their now if it has never been raised,as long as it don't have "riviet"looking things attached to sides of wick to fit it wick housing(Sears is good for that)If it a round or square heater it pretty much the same you have to remove the outer shell of heater, its always a good idea to dump out fuel first,at the base of wick their is usually 3 wing nuts or screw that hold wick Assembly in,after removing them you pull housing up to remove ,notice how the old one is on and remove and put new one on,when putting back in make sure wick fans out and goes to bottom tank,put back to gether and your done,most replacement wicks come with directions and height setting for the wick, Its not real hard as long as you pay attention
Nov 26, 2008 | Heating & Cooling
Wickes
I went to a site that has questions and answers about a kerosun heater. from what I gathered, instructions on how to replace the wick are included with the replacement wick.
Dec 04, 2007 | Northern Tool 10,600 BTU Radiant Kerosene...
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
