Question about Trendware TEW-639GR Router
Power link unstable. all lan ports blink amber.
Dell dimension amber light blink
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.
Remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 27, 2014 | Dell Dimension 9200 PC Desktop
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
My power button is blinking an amber color and my computer will not power up
An steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Nov 26, 2011 | Dell Dimension E510 PC Desktop
Power button light blinks amber not turning on
Nov 10, 2011 | Dell Dimension 2350 PC Desktop
Blinking amber light xps 420
A Blinking Amber orYellow power button means that the power supply is receiving power from thesource but is unable to properly distribute it to the components. This can becaused by a defective power supply or a defective motherboard. Just to makesure that nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
Feb 17, 2011 | Dell XPS 420 PC Desktop
I have a switch Dlink (DES-3026). All the status LEDs are blinking together with orange color. Is there any problem in that?
Blinking LEDs show data activity (Send & Receive) at the connected ports. So, there is no problem as long as the switch is performing well
Good Luck!
CreativeTECH
Feb 01, 2011 | D-Link Computers & Internet
Switch with 8 leds blinking (and not working)
You probably have to buy another switch. However, before you try that - the eighth most right cable - switch that out to see if it was a cable problem. That's an easy thing to try before you buy another switch.
Mar 17, 2009 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
By dell dimension4300 power switch is just blinking amber and wil
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 23, 2008 | Dell Dimension 4300 PC Desktop
Vonage does not work with D-Link router
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
Jun 17, 2008 | D-Link DI-704P Router
The internet port light keeps flashing amber
Frustrating that the answer is not readily apparent from Netgear but it's really pretty easy. An Amber light on the Internet Port means the same as an Amber Light on a Lan Port. That is, the router senses the connection is less than the maximum speed. No, Netgear does not document this in their manual but will 'fess up to it if you talk to a real Tech Support person. There is no difference in the lights in the Internet Port and Lan Ports. They are both "Ports". From Netgear:
Green - The LAN (local area network) port has detected link with a 100 Mbps
device.
Green Blinking - Data is being transmitted or received at 100 Mbps.
Amber - The Local port has detected link with a 10 Mbps device.
Amber Blinking - Data is being transmitted or received at 10 Mbps.
No light - No link is detected on this port.
But your Internet still works you say. Yes, that is because your connection to your ISP is just about always less than the minimum speed, so you don't notice any difference other than an annoying change in color on the router. This usually can be resolved by resetting the modem. That will cause the ISP to reconnect to you with a different modem at their end. They have a piece of equipment that is less than optimal but if they are like most ISPs, they will not have a clue (or an interest in getting it fixed). If you call your ISP, they will probably set you on a whole course of checking your computer network drivers, updating router firmware, resetting and rebooting your computer, etc. All steps listed in the Official HelpDesk Guide to Getting the Customer Off the Phone Manual as one of those usually will eventually will be a reset of the offending piece of equipment.
Apr 18, 2008 | NetGear WGR614 Wireless Router
Trendware TEW-639GR Router Logo
44 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
