Question about Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor
I recently acquired a sceptre x9g Naga V monitor which has developed a problem. It produces a wonderful image which may last 5 min or 5 sec, then goes black. If I turn it off or unplug the monitor the start it again, it comes up,but just like before, it shuts down somewhere between 5 sec & 5 min.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sceptre Master
  • 848 Answers
I recently acquired a sceptre x9g Naga V monitor which has developed a problem? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
Sceptre LM004 Power Supply Backlight Inverter for X9G KOMODO
Posted on Mar 22, 2015
  • 11,361 Answers
It may have dying power supply due to bad DC filter caps like the 17" version.
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 31, 2010
I have a Sceptre X9G-Naga II and two ceramic capacitors that are in the power supply are fried. The capacitors are C11 and C12. Anybody knows the value of these capacitors and where Can i get them?
I think they are MOVs in the primary AC side. Can you post the pictures, or send them to me at budmrtn@aol.com. Most MOV are blue in color, ceramic cap is usually orange/yelllowish color.
Nov 10, 2010 | Sceptre X9G-NagaIV 19" LCD Monitor
I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
Feb 19, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Acquired an X7s-Naga monitor at an auction Model
We carry power cables, ac adapters and signal cables for LCD monitors. They are in stock and ship from Louisiana. Contact me for pricing and ship info.
Buddy
Corporate Computer
tech@ccl-la.com
318-447-9040
Dec 14, 2009 | Sceptre X7s-Naga II Monitor
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre naga x9 no osd
bad display board replace if you can find one on ebay
May 10, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor Logo
197 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
