Question about Refrigerators
FRIDGE FREEZER SAMSUNG RS21DGRS THE ICE CUBE M/C ISNT WORKING THERE IS NO WATER TO IT BUT THERE IS WATER TO THE CHILLED WATER DRINKS M/C
    Filmmaker:
    Uploaded 5 video answers.
  • 22 Answers
Samsung rs21 ice maker troubleshooting video
Posted on Aug 17, 2014
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Samsung fridge freezer problems
Posted on Jan 16, 2011
Ice maker set up
it takes a couple hours for ice and not as long for water to chill .
Feb 09, 2015 | Samsung 26 cu. ft. Side by Side...
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
Jun 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Refrigerator isn't very cold- drinks are just slightly chilled
Usually caused by failure of defrost system, Air ports from freezer to fridge blocked by ice
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | Whirlpool Refrigerators
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Samsung rs2555sl ice maker trouble
check to make sure that the tube that fills the ice maker is not froozen upo and causoing this problem
Feb 21, 2009 | Samsung RS2556 Side by Side Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Freezer burn on ice-cubes
Black mould around the freezer seal is normal if it has built up over a long period of time or has stood in damp environments. Normally hot soapy water can clear this right up. The ice taste would probably be resolved by fitting or changing the water filter, and / or cleaning the ice maker module located at the top of the freezer section and any route that the ice would take. Cleaning solutions for ice makers are available you just might need to call a local engineer for some advice on where to get some in your area. Hope this helps.
Feb 07, 2008 | Refrigerators
Refrigerators Logo
285 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
