Question about Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw: DW7881 Worklight
Bad knocking in scroll saw it is a dewalt dw788 20 inch i believe it is the bearings in the con rod assembly but i can not remove the part can you tell me how brenda
    Problem Solver:
  • 13 Answers
Have you double checked to make sure your tention hold down is not hitting against the upper arm of your saw?
Posted on Jan 03, 2011
Makes knocking noise that sound like something is loos banging only when jeep warms up and only in gear
TROUBLESHOOTING ENGINE NOISES
A KNOCKING SOUND IN THE ENGINE IS MOST LIKELY CAUSED BY ONE OF THE FOLLOWING
1. PISTON SLAP: Makes a sharp metallic noise. Idle engine and short out each cylinder plug. The noise will disappear when plug with bad piston is shorted. Noise will also disappear at acceleration. This can be caused by worn or out of round cylinder, or broken piston ring. Correct problem by re-boring cylinder and/or replacing piston.
2. VALVE NOISE: Makes clicking or rattle noise. Caused by excessive wear on valve stem or lifter, out of adjustment, or stuck valve. Correct by adjusting valve clearance, replace worn valve or lifter, regrind cam, replace valve guide and /or valve. A stuck valve can sometimes be loosened by passing oil through the carburetor while engine is running.
3. ROD BEARING KNOCK: Makes sharp metallic noise similar to a piston slap. Detection is opposite of piston slap. Rod knock is not heard at idle. Knock becomes louder as engine speed is increased. Caused by excessive rod bearing clearance. Correct by adjusting rod bearing clearance to .0015 inches by removing shims. May require re-pouring rod bearing.
4. REAR MAIN BEARING KNOCK: Makes dull knocking or thud noise. Detected at speeds between 20 and 50 MPH. Knock will normally decrease or disappear while pulling or decelerating. Noise will be detected the loudest at normal driving speed, when not pulling or decelerating. Correct by adjusting bearing clearance to .001 to .0015 inches. If knock is excessive, crank should be checked for out of roundness. May need to re-pour all main bearings to correct.
5. TIMING GEAR KNOCK: usually the most difficult to diagnose. If gear is loose or badly worn it will knock in all ranges. Run engine slightly above idle speed. Slowly open and close throttle. Knock will continue to be present, but just as engine slows down knock will become a slight rattle. Remove timing pin and reinsert into timing hole on timing gear cover. Press timing pin tightly against timing gear and accelerate slightly above idle. Knock will significantly be reduced or disappear. Correct by replacing both timing gear and crank gear as a matched set. The two gears should have a backlash clearance of .003 to .004. If more than .009 inch backlash, an oversize (.005) timing gear should be installed.
6. WRIST PIN SLAP: This can not be detected by shorting out the cylinder plugs. Rapidly accelerate and decelerate the engine speed. The engine will pass through a certain speed range when the wrist pin will rattle at about the same pitch as a valve tappet noise. This can be corrected by installing a new wrist pin bushing in the rod or new wrist pin f badly worn. Wrist pin should fit the piston and connecting rod with a tight metal to metal fit. The pin can be pushed into the piston and rod with a slight pressure of the hand. Pin to rod clearance is .0003 to .0005 inches.
Dec 07, 2013 | Jeep Cars & Trucks
Making knocking sound
Dec 06, 2013 | Nissan Cars & Trucks
V6 knocking noise
Dec 06, 2013 | Cars & Trucks
Toyota tercel 1988, engine knock. Replaced pistons rings and con rod brgs. Engine still has knock but not as survier. Has anybody changed main bearings with engine installed?
You will have to remove crank to replace and removing motor would be my suggestion...Would also suggest having the crank turned.......hope this info helps and good luck......please rate my post....
Aug 09, 2012 | 1988 Toyota Tercel 2 Door
I have a Dewalt scroll saw and all of a sudden the cuts are irragular. it is fatter at the bottom then it is on the top, which makes for a bad fit. I have tired changing blades, made no difference. ...
Check the bearings in the lower part of the blade drive assembly (take the blade out to check) which may be allowing the mechanism to wobble. Also, check the mounting bolts holding the mechanism to the table. Hope this helps!
Nov 24, 2010 | Garden
Need replacement parts - accessories
If the kickback arm you seek is the type that is a round bar with pointed fingers on the bottom, I had the same problem. (different model DeWalt) I gave up trying to find one, and finally just made one. It was pretty easy, and works very weill I bought a piece of steel rod (1/2 inch I think) a steel repair plate (from which I cut a pair of tear-drop shapes with a hacksaw and file) a 1/4 inch hex-head bolt (which had about 1 inch not threaded) and a 1/8 inch roll pin. I looked at various pictures on the web to determine the shape of the teardrops. I drilled a 1/4 hole in the 1/2 rod. I cut the threads off of the 1/4 bolt so it was still long enough to accept the 1/2 rod, the two teardrops, 2 washers and the 1/8 roll pin. Then I put an 1/8 hole in the bolt allowing enough clearance so that the teardrops would swing freely. It works like a champ. One minor flaw is that with only two of the teardrops (instead of several) and being separated by 1/2 inch, it would be possible to make a skinny enough rip that only one teardrop would contact the board being ripped, leaving the other peice unguarded.
Jan 23, 2010 | Delta Machinery 10" Professional Radial...
I'm looking for the 2000 isuzu rodeo 3.2L v6 connecting rod bearings torque specs.
1. Check the connecting rod alignment If either the bend or the twist exceeds the specified limit,the connecting rod must be replaced. Bend per 100 mm (3.937 inch) Limit: 0.15 (0.0059) Twist per 100 mm (3.937 inch) Limit: 0.20 (0.0078)
2. Measure the connecting rod thrust clearance. Use a feeler gauge to measure the thrust clearance at the large end of the connecting rod If the clearance exceeds the specified limit, the connecting rod must be replaced. Standard: 0.16 mm - 0.35 mm (0.0063 inch - 0.0138 inch) Limit: 0.40 mm (0.0157 inch)
3. Measure the oil clearance between the connecting rod and the crankshaft.
    1. Remove the connecting rod cap nuts and the rod caps (12). Arrange the removed rod caps in the cylinder number order.
    2. Clean the rod bearings and the crankshaft pins.
      1. Carefully check the rod bearings. If even one bearing is found to be damaged or badly worn, the entire bearing assembly must be replaced as a set. Reinstall the bearings in their original positions. Apply plastigage to the crank pin.
      2. Reinstall the rod caps (12) to their original positions. Tighten the rod cap nuts. Torque: 54 Nm (40 ft. lbs.) Note: Do not allow the crankshaft to rotate.
      3. Remove the rod caps.
        1. Measure the width of the plastigage and determine the oil clearance. If the oil clearance exceeds the limit, replace the rod bearing as a set. Standard: 0.019 mm - 0.043 mm (0.0007 inch - 0.0017 inch) Limit: 0.08 mm (0.003 inch)
        2. Clean the plastigage from the bearings and the crankshaft pins.
May 21, 2009 | 2000 Isuzu Rodeo
Dw788 scroll saw knocking/vibration sound
http://www.scrollsaws.com/SawReviews/DewltTuneUp.htm is a link to a possible solution on scrollsaws.com
It did not fix my problem. My problem is in the "CON ROD ASSY" (part #82) and I found VERY TINY almost microscopic play in the bearing. I took the assembly apart, put it back togerther SEVERAL times and on my last ditch effort, it solved the knocking noise.... I don't think it will last long and probaby just have to replace the part or try to buy the same type bearing for cheap and press it in without damaging it so I don't have to get ripped off on the high dollar Dewalt part.
Mar 16, 2009 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw:  DW7881 Worklight Logo
421 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
