Question about LG LRE30755ST Kitchen Range
The burners on my LG LRE30755ST range will not work. I tried shutting off the power supply and turning it back on. The Power Failure code lights on each burner panel button but they still will not work. Thanks.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
The PF message will appear whenever there has been a power interruption to the appliance. To clear the PF message touch CLEAR/OFF control pad and be sure to reset the clock with the correct time of day.
• To clear the HS message touch ON/OFF pad.
if this does not correct the problem. you then have a defective control card, inside the range.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
Replace burner
it should just plug in at the back wiggle it out
Oct 23, 2013 | LG LRE30755ST Kitchen Range
No gas to the burner or oven
Hello deodatramdin - If both the range and oven are not working, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. While the unit is turn off, confirm that the shut off valve on the gas pressure regulator is in the "ON" position (typically located on the back left-hand side of the range). This valve shuts the gas off to the oven. Once you have verified, turn the range back on. If it proves to be ineffective, then the range could possibly be experiencing an issue with the EOC, wiring failure or faulty power supply. Contact a certified technician to move forward accurately and to assist with the repairs.
Jan 30, 2013 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire es 200/300 electric range will not turn on and burners wont heat
The first thing I would check is the incoming power supply. Make sure you are getting at least 120 volts on each leg (red to center, black to center) and between black to red, you need at least 240 volts. Sounds like you are having a household power supply issue.
Jan 27, 2013 | Kitchen Ranges
My kenmore elite stove model#790 the oven and broiler do not heat up but the fan runs
Since none of the burners or elements will heat, I recommend that you shut off the house circuit breakers for the range. Your symptoms point to a voltage supply problem. The range should have a double breaker (the two circuit breakers are probably connected together with a metal clip). The range clock control will light up if only one leg (L1) of that power supply is provided to the range. If the second leg of power (L2) is missing, then none of the burners or oven elements will heat. You could have a problem with the circuit breakers or the wiring on the terminal block at the back of the range. With the breakers shut off , I recommend that you pull the range out and check the wiring on that terminal block. Based on your description, you may find a loose connection or burnt wiring in that area. The image below shows wiring information for the terminal block and the junction box for the range. This information should help you check that issue. If you can find a wiring failure and restore a proper voltage supply to the range, then the stove top burners and oven elements should heat properly.If you find no problems with the wiring, then you could have a bad circuit breaker or a problem with the house voltage supply for the range. An electrician will normally need to diagnose and repair that type of failure. I hope that this information helps. If you need more assistance, reply with additional details. If you need parts, you can order them from the Sears PartsDirect website.If you get to a point where you need to have a service technician repair this failure, you can schedule service through this link: Sears Home Services .
Nov 27, 2012 | Ovens
Presumed bad circuit board on my LG LRE30755ST electric range
You may wish to try removing and re-seting some of the connectors on the back of the control panel...worked for me when our oven and timers stopped working.....
Remove the sheet metal panel at the top of the back of the oven..three phillips screws....then slide the two blue ribbon, wire connectors out, and re-seat them a few times to get a good connection.
Try to un-seat and re-seat some of the others aswell...perhaps un-plug from the wall first....but make sure there is good connections....then re-plug in, and see what happens...
Jan 02, 2010 | LG LRE30755 Electric Kitchen Range
Lg oven not workink
Dec 01, 2009 | LG LRE30755ST Kitchen Range
LRE307555SW/SB/ST\03 Nothing works, nothing.
Donna:
Have you checked the main power input terminals first? they do carry a lot of current and are subject to burning off,then if electronically controlled,it could be an electronic fuse in the ovens control panel/keypad shutting things down,somewhat unlikely though...let me know and thank you for using this site.....Dan
Nov 04, 2009 | LG LRE30755ST Kitchen Range
The two large burners will not turn on, it started with just the inner burner on the dual size (the switch showed it on but it did not heat) now neither front burner switch will turn on
you are going to have to buy a new burner part. if you are able to open the stove top and look closely at the element inside you should notice that somewhere along the lines of teeth, it has broken.
Jun 28, 2009 | LG LRE30755ST Kitchen Range
LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Jan 24, 2009 | LG 30 in Kitchen Series Dual Convection...
LG LRE30755ST Kitchen Range Logo
489 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Mike Carew
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
