Question about Kohler Plumbing
I have a Kohler faucet on my kitchen sink. Model 112.18.1, which is a single handle faucet. The faucet body leaks badly when the water is turned on. Bad o-ring inside faucet body?
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Kohler Fairfax single control kitchen sink faucet
Remove the air-irater at the end of the faucet where the water comes out. That is where 99% of clog are on faucets. If that does not do it then you need to replace the cartridge.
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Mar 19, 2010
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
How do I disassemble a Kohler kitchen faucet
Remove sprayer and hose from faucet body.
Remove handle and cartridge.
Pull up on body.
Replace parts and reinstall in reverse order.
Aug 31, 2014 | Kohler Model 10433: Fort® Single-control...
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
How do I open the body of K-10430 apart to replace the valve cartridge kit that's leaking
The handle has a allen set screw loosen that until the handle comes off then the bonnet nut will unscrew revealing the bonnet cap and washer the cartridge should be under that most kohler's require a special tool to remove cartridge(turn water to faucet off prior to working on faucet,also note how everything is removed it needs to be replaced in same order especially the cartridge,also you should use plumbers grease to coat all seal when replacing everything).
Jun 03, 2011 | Kohler Model 10430: Fort® Single-control...
Kohler - Coralais Pull-Out Spray Kitchen Faucet
te leak most likely is the cartridge you need to take the handle off and there will be a lock nut under where the handle was, turn the water supply off and remove the nut the cartridge will pull staight out, cartridges can't be repaired they need to be replaced. Watch out because some cartridges cost more than what the tap is worth
Jul 12, 2010 | Kohler K-15160-7 Coralais single-control...
Mar 19, 2010 | Kohler Fairfax Single Control Lavatory...
I have a Kohler Forte Single handle faucet, and I'm seeing leaking down below the sink in the cabinet. I tried reconnecting the Kohler piece to where the water comes out, but now it's even worse. It looks...
Turn off your water supply to the sink the disconnect the supply lines to the faucet. Reconnect supply lines making sure to use plumbers pipe joint compound of teflon tape. I've found teflon tape to be better. When installing the supply lines make sure that the threads aren't crossed and the retaining nut is snug.
Mar 12, 2010 | Kohler Model 10433: Fort® Single-control...
Leaking kohler faucet
Where the spout pivots on the main body, there are a couple of washers, you can replace these washers pretty easily by removing the handle and then the "cover" from the unit. The water has to be shut off before you do this. I would take this oppurtunity to replace all the washers.
Mar 08, 2009 | Kohler K-15176-PT-7 Coralais...
Plumbing Logo
1,504 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
