My washing cycle on my hotpoint wmt03 has finished but the door locked light remains on and the door is liked. How can I get my washing out?
gittos73
  • 244 Answers
SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Posted on Aug 23, 2007
barkencoa
  • 3463 Answers
SOURCE: hotpoint wd420 washer dryer door won't open.
Press the start cancel button for at least 2 seconds, switch off, leave for 2 mins,switch on again holding the botton for 2 secs, then press start cancel buuton again for at least 2 seconds, hope fully ,this should do ths trick.
Thanks
Plz rate my solution
Posted on Jan 23, 2009
  • 21 Answers
SOURCE: Front loader door will not open after a washing cycle is finished
call the repair man it is a comp. issue
Posted on Feb 14, 2009
pappapumpdaf
  • 635 Answers
SOURCE: My Hotpoint Aquarius WF430 1300 doesn't complete its cycle
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Posted on Mar 05, 2010
SOURCE: Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
Posted on Jul 20, 2010
Door stay locked after finished washing hotpoint w/machine ref 9526
See if you notice any water still inside the washing machine, if so run another spin cycle to try and remove it as it will not open if there is still water inside.
If you don't see any water inside, try unplugging it and letting it cool off, the lock should release after this
Jul 03, 2016 | Hotpoint Washing Machines
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
My Hotpoint wdl540 has finished its wash cycle but the lock light remains on and the door is locked. Tried all sorts to get it to unlock including running another cycle.
Firstly, to get the door open, if you unclip the bottom kick plate, you will find a small green tag hanging down on the right hand side. It is a door lock bypass. if you pull gently down on the tag about a centimetre, while it is pulled down, you will be able to open the door.
Turning to the problem its self, two issues can cause the door to remain locked. In order of which is more likely:
1) While it's ucommon, it's not unheard of that the 3 wire connector that clips to the bottom of the door swich inside the chassis develops a poor connection. Typically, this will cause one of the connectors to arc and burn the connection on the connector and if you're unlucky, the door lock mechanism as well. Remove the lid of the machine. Remove the door lock mechanism by unscrewing the 2 screws that can be accessed through the door aperture and lift the lock mechanism out to examine it (Note that the green tak is on a long strip that connects to this mechanism, so take care to lift this away in conjunction with the lock as you remove it. You may need to replace the connector and possibly the switch too.
2) Since power to the door lock runs through the motor circuit, if the motor brushes are heavily worn, the door lock won't disengage until they are replaced. This is absolutely counter-intuitive and it took me a few years of experience to figure out this little gem!
Sep 21, 2015 | Hotpoint Washing Machines
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
I have a hotpoint ultima extra and the door won't open after the cycle has finished. The door lock light stays on. I have tried turning it off and running another cycle.
unplug unit for 1-2 minutes plug back in and then usually it will reset the computer.If this dont work you will have to take off top and pick the lock and replace door lock
Oct 27, 2010 | Washing Machines
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Door locked
Press 'end of cycle' button for over 3 seconds, & wait for a couple of minutes then try the door. Do not force door.
Mar 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Door Lock
door lock blown this sometimes blows tracks off the main pcb behind the control panel. appliance doctor
Jan 29, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
