Question about Sony HVR-V1U Mini DV Digital Camcorder
Is there a quick fix when the camera keeps saying the tape is locked? I've tried different tapes and switched it off and on, from vcr to record and nothing is letting me record.
    Genius:
  • 1,812 Answers
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Dec 31, 2010
Tape is stuck, can't remove it
I remove a stuck tape from a VCR by taking off the outside cover. (My unit was held together by 5 screws.) This allowed me to access the tape and check where it was locked. I had to loosen a twisted tape from the mechanism and then I could eject it. (Note: I unplugged the deck before removing the cover.)
I hope this helps.
(I've been fortunate; I've only had to do this on VCR units (not VCR/DVD) that were out of warranty. If your MWR20V6 is still in warranty, you may not want to open the case at home.)
Dec 17, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
Aug 13, 2009 | Samsung Televison & Video
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
I get an error message everytime I try to record
There is a switch on the VCR that says "tape/other". Change the switch from "other" to "tape" and you should no longer receive this message.
Mar 22, 2009 | ION Audio VCR 2 PC USB VHS Video to...
Toshiba D-VR650 can't tape says canot record protected image
THERE IS A TAB ON THE VCR TAPES IT CAN BE BROKEN OUT TO KEEP PEOPLE FROM TAPING OVER YOUR PERSONAL TAPES.LOOK AND SEE IF THIS IS NOT BROKEN OUT. IF IT IS PUT SOME TAPE OVER IT AND IT WILL RECORD ON THAT TAPE AGAIN.
Feb 10, 2009 | Toshiba D-VR650
The video machine bleeps continually and shows a message E-3
I think the E3 error code indicates an error with the tape drive mechanism. If it ate a tape, this would indeed be the problem. Time Lapse VCR's are not very popular anymore, everything has gone to digital. It would most likely cost you more to fix that VCR than to switch out to a digital recorder.
Other advantages are -
No tape to change
Very good recorded image quality compared to VCR
Most digital units have capability for remote viewing over the internet
You can set the unit to "alert" you if there is movement in the garden
Sep 25, 2008 | Home Security
Magnavox TV: Somehow the record button on the remote will not record VCR. It ejects the tape and does not record. Please help. Thank you.
Try Using a new VHS tape. If the new tape ejects when press recording, the recording switch inside your VCR could be defective.
Let me know if you require further assistance.
Aug 26, 2008 | Televison & Video
When I try to play PAL tapes, there is no picture
You also need a PAL television or monitor to be able to view them. If you don't have a PAL compatible monitor or TV it will not work because the resolution and scanning is very different than an NTSC monitor. Your canon camera is probably designed only for NTSC use if it was sold in North America and can't be used for PAL use.
Jul 31, 2008 | Sony DSR-11 DV / Mini DV VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony HVR-V1U Mini DV Digital Camcorder Logo
94 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
