Question about Maytag Dryers
I placed a small load of clothes in the dryer turned it on and came back to the dryer 5 minutes later and smelled like somthing was burning. I don't believe the dryer ever started. I unplugged the cord from the wall outlet and plugged it back in and the dryer does not go on. The Dryer is a Maytag Perfoma- Model# PYE2300AYE Seriel Number 10170940AC
  • 32 Answers
Normally what happens in this case is the dryer belt snaps. You can test this by turning the dryer on without any clothes in it. If the drums heats up but does not turn/rotate the first thing to check is your belt. You could check the belt yourself if you have the knowhow or the expertise or you could get someone to have a look for you.
Posted on Dec 30, 2010
My dryer leaves a weird smell on my clothing anything i dry no matter what setting i use , how big or how small the loads are and it smells.
Try checking the back of the dryer, there should be a foil tube type exhaust. Sometimes if the tube falls off the wall (mine had a plug on wall) the lint backs up and burns or cooks. That's the cause of your smell.
U can also use a vacuum and try to vacuum the lint trap at the front of the dryer. U might have to unscrew the grill.
The bottom line is that there is lint somewhere in ur dryer and that's what is causing ur smell.
Nov 18, 2013 | Dryers
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Dryer is not drying- wet lint in the filter
Maybe you have a dead animal, (mouse,rat etc) inside of unit. They could have died whilst chewing the wiring, hence the no heat problem. Take off the panel on the back of unit or tip it on it's side. You should be able to see the inner workings and anything else. If not, buy a new dryer, this one must be costing heaps to run.
Dec 14, 2011 | Dryers
I have a stackable Frigidaire Gallery Dryer. It won't turn on...
turn the start and it's like the drum gets stuck. then starts smelling like burning.
Mar 05, 2010 | Frigidaire Dryers
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
3 lights on my sephia kia on at the same time
Sounds like some of your internal wiring might be burning up. Check your Fuses too,
You can't drive around like this too long; take it to a garage to get it repaired now rather then later.
I hope this helps,
Thanks.
Mar 15, 2009 | Kia Rio Cars & Trucks
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Dryer not drying clothes properly
Replace the vent tubing, sounds like something is stuck or it is crushed somewhere. So replace it for about 5 dollars and see if that works. It should since you disconnect the hose and it drys right away
Feb 10, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
My dryer in my stackable washer/dryer quit
I Think the belt got binded on the motor spindle and the burning smell was the belt burned through by the spinning spindle
Mar 23, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
