Question about Alpine ERE-G190 Car Equalizer
I have an Alpine 3342 sond feild controller, and are not sure on the wiring of the six pin connector, Blu/Wht, Pnk/Wht,Yel. I connected this myself to my own car years ago. My son found it and wants me to hook it up, I've forgotten. ANY help would be a PLUS, thank you.
    Scholar:
  • 127 Answers
2003 Pontiac aztek. What are the three connections for on the ignition module
B+ voltage supply , ground , crankshaft position sensor B input , IC timing control , IC timing signal , low ref. engine speed signal , etc... Do you know what these are ?
Ignition Control Module (ICM) -- C1
Connector Part Information
• 12162261
• 6 Way- F Metri-Pack 150.2 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
TAN/BLK
424
IC Timing Signal
B
WHT
423
IC Timing Control
C-D
Not Used
E
PPL/WHT
430
Low Resolution Engine Speed Signal
F
RED/BLK
453
Low Reference
Ignition Control Module (ICM) -- C2
• 12162184
• 2 Way-F Metri-Pack 150.2 Series Sealed Pull To Seat (BLK)
Pin
Wire Color
Circuit No.
Function
A
YEL
573
CKP Sensor 1 Signal
C
PPL
574
Low Reference
Ignition Control Module (ICM) -- C3
• 12162194
• 2-Way F Metri-Pack 150.2 Series Sealed (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
51
Ground
B
PNK/BLK
239
Ignition 1 Voltage
Nov 07, 2017 | Pontiac Cars & Trucks
Do you have switch schematics
No diagram available, but wiring is as follows: PPL/BLU wire connects power from FUSE 21 in the interior fuse panel; Pin 1 - WHT/PPL to RF window switch; Pin 2 - YEL/PPL to RF window switch; Pin 3 - WHT to RR window switch; Pin 4 - YEL to RR window switch; Pin 5 - N/C; Pin 6 - WHT to LF window motor; Pin 7 - YEL/GRN to one touch down window relay; Pin 8 - WHT/BLU to LR window switch; Pin 9 - YEL/BLU to LR window switch; Pin 10 - ORG/YEL to interior lights system. A second PPL/BLU wire connects the rear cut off switch to the left and right rear window switches.
Jun 21, 2014 | Drills
Where can i get an 01 silhouette pcm pinout
PCM pinout diagrams
2001 silverado (Thanks Banker099)
Try this link for page below
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc1pcm2001.gif
Powertrain Control Module (PCM) C1 (BLU)
• PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
Fuel Injector 3 Control
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
12
DK BLU/WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data [Secondary]
15
DRK BLU/WHT
774
UART Serial Data [Tertiary]
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
YEL
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal [- Bank 2 Sensor 1]
25
TAN
413
HO2S Low Reference (Denso Sensors) HO2S Low Signal (Delphi Sensors)
26
TAN
1667
HO2S Low Signal [- Bank 2 Sensor 2]
26
TAN
413
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal [- Bank 1 Sensor 2]
28
TAN
413
29
TAN/WHT
1653
HO2S Low Signal [- Bank 1 Sensor 1]
29
TAN
413
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRA
48
CPP Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRA
720
Low Reference (w/o Delphi HO2S)
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRA
474
5 Volt Reference (FTP Sensor)
46
GRY
474
5 Volt Reference (TPS Sensor)
47
GRY
597
5 Volt Reference (MAP Sensor)
48
GRA
596
5 Volt Reference (EGR Sensor)
49 50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
Not Used
57
ORN
440
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRA
720
Low Reference
63
TAN
413
64
Not Used
65
PPL
1670
HO2S High Signal [- Bank 2 Sensor 2]
66
PPL
1666
HO2S High Signal [- Bank 2 Sensor 1]
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [- Bank 1 Sensor 2]
69
PPL/WHT
1665
HO2S High Signal [- Bank 1 Sensor 1]
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control
80
ORN/BLK
510
Low Reference
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc2pcm2001.gif
May 23, 2014 | 2001 Oldsmobile Silhouette
2004 kia spectra car cd wiring color codes
Guessing it is an EX. The instrument panel fuse box contains a 10A AUDIO fuse that supplies power on a PNK wire. There is also a 15A ROOM fuse which probably supplies dial illumination (it's also a PNK wire!). LF speaker and tweeter: YEL/BLK and BLU/RED. RF speaker and tweeter: BLK and YEL. LR speaker: BRN and WHT. RR speaker: GRN/ORG and BLU/ORG
Oct 08, 2012 | 2004 Kia Spectra
1992 dodge dynasty radio diagram
Assuming the radio connects to the RS amplifier, the harness is as follows:
From fuse 13: PNK or BLK -> PNK/LT BLU -> PNK or BLK -> PNK/LT BLU -> radio (!)
From fuse 20: RED/WHT -> radio
From fuse 10: VIO -> amp
From radio: ORG and BLK/YEL to interior lights
From radio to amp: DK BLU/RED, BRN/RED, DK BLU/ORG, BRN/ LT BLU, VIO, DK GRN or DK GRN/WHT, DK BLU/WHT, BRN/YEL
From radio to pwr ant: DK RED/GRN
From RS amp to:
R. door: LT BLU/VIO and LT BLU/DK GRN
R. front: ORG/BLK and ORG/RED
R. rear: TAN/BLK, TAN/RED, TAN/DK GRN, and TAN/VIO
L. rear: WHT/DK GRN, WHT/VIO, WHT/BLK, WHT/RED
L. front: YEL/BLK and YEL/RED
L. door: LT GRN/DK GRN and LT GRN/VIO
Mar 17, 2017 | 1992 Dodge Dynasty
No spark all ohmeter checks ok
4-pin upper left=blu/wht
upper right=yel/wht
bot left=blu
bot right=yel
6-pin upper left=yel/with blue stripe
upper right= green
mid= blank
mid= blank
bot left=blu/with yellow stripe
bot right=blk/wht
can you rate this thanks!
Apr 29, 2010 | 1987 Honda CBR 600 F(1)H
1993 ford thunderbird stereo installation guide/ wiring guide
bat.-lt.gr/ppl; grnd-blk; ign-yel/blk; lights-lt.blu/red & org/blk; grnd-blk/org; L.F.-org/lt.grn & lt.blu/wht; L.R.-pnk/lt.grn & tan/ylw; R.F.-wht/lt.grn & dk.grn/org; R.R.-pnk/lt.blu & brn/pnk
Nov 07, 2009 | 1993 Ford Thunderbird
Need to wire a new car stereo for ford 1991 fairlane i am having trouble working the colour coding of the old wires as alot of the new colours are different
colors are:
gry/grn + gry/blk -> rt frt
org/grn + org/blk -> lt frt
blu/red + blu/blk -> rt r
pnk/grn + pnk/blk -> lt r
+12V - grn/yel
+12v switch -> blu/wht
ant: ( if you have it) -> red/blu
lights: brn
earth- > blk
Sep 16, 2009 | Pioneer DEH-30MP CD Player
I need a wiring diagram for a stock radio
this info comes from 12volt.com :
RADIO 12V = yellow
RADIO SWITCH = purple
RADIO ILLUMINATE = red/white
POWER ANTENNA = green/white
LF SPEAKER = (+)blu/wht (-) blu/yel
RF SPEAKER = (+)brown (-) brn/wht
LR SPEAKER = (+)lt. grn (-) blk/yel
RR SPEAKER = (+)blue (-)pink
this info comes from alldata :
LH FR SP (-) GRN/YEL
LH FR SP (+) PPL
RH FR SP (-) BRN/WHT
RH FR SP (+) BRN
BATTERY BLUE
ILLUM CONTROL RED/YEL
LIGHTING YEL/RED
ACC PINK
AMP BLU/WHT
LH RR SP (-) BLK/PNK
LH RR SP (+) ORG
RH RR SP (-) GRY/RED
RH RR SP (+)GRY
Omega and alldata match , i expect the second set to match .
obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
Jan 10, 2009 | 2000 Nissan Sentra
Wire diagram
guynoir..with alpine your other set of speakers would most likely run through an amp ,which may connect up by the rca leads or a din plug , this is where your fader comes in to play.i was an agent for alpine
Feb 07, 2008 | Car Audio & Video
Alpine ERE-G190 Car Equalizer Logo
552 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
