Question about Microwave Ovens
Microwave started smoking and stopped working
  • 1 more comment
  • 4diana Dec 03, 2008
    Kenmore
    model 721.63109.300
    It made a pop and smelled of electrical burn over a month ago. We found a small black burn mark inside the upper door area. It has continued to work since that time.
    However, yesterday, it happened again. Now there are two small holes and black burn marks about one inch away from the previous mark. Safe to use or replacement time:
  • Anonymous Dec 12, 2008
    2 years 2 months old and just started smoking out the bottom left side within seconds of starting it.
  • jturnervc Mar 30, 2009
    Same exact problem as 4diana.
  • Microwave Ovens Master
  • 9,098 Answers
Did it smell electrical or like something arcing?
I would suspect your magnetron or high voltage transformer has failed.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
I have Lg model LMV1630bb started smoking while in use then stopped working
Posted on Apr 12, 2015
Had a power surge, microwave started to smoke. Reset power in the house and microwave works fine. 1) Is there anything I should be concerned about? 2) If I continue to use it, can it catch on fire?
Microwave ovens have a lot of safety devices built in. Not sure why or where it was smoking from but without removing the cabinet and having a visual look for something burnt, it would be impossible to say. If the machine is now working OK, ??? who knows. All I can say is that for the next few future uses of the machine, I wouldn't leave it unattended in case there is something that has failed. Chances of fire in a microwave is possible but this is usually something that you are cooking that catches fire, not the machine itself. I have seen the mica cover plate burn in the cooking compartment. It may be that ? Its a small squarish plate that is usually on the side of the oven compartment. It stops food etc and splatters from going into whats known as the waveguide tunnel (The part where the microwaves come out) On some machines, this cover may be plastic. Have a close look inside the oven compartment for a cover that has burn marks or discoloration.
Apr 13, 2015 | In Microwave Ovens
Microwave started smoking when i turned it on
Unplug the microwave and take it out check if any food items were present before u put oat meal inside it.IF there in nothing then check for any wire leaks.The smoke may have been caused by leakages in the microwave wire.Check both the things
Dec 07, 2011 | Panasonic NNSD697S Stainless Steel 1300...
Microwave is making humming noise and started to smoke and stop working
sounds like the fan inside oven seized, causing the smoke and popped the internal fuse. If you have any appliance repair shops around, they should be able to fix it for you cheaper than replacing the entire unit. Make sure you leave it unplugged, I know thats abvious but had to mention. Good Luck!
Apr 18, 2011 | LG LMV1630ST Microwave Oven
My Kenmore OTR Convention microwave oven started smoking an awful smelly smoke or gas then stopped working. Can this be fixed? Thank you so much!
It probably cannot be economically fixed...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 13, 2011 | Kenmore 80809 Microwave Oven
Microwave stopped working with no warning. They had a recall on this model and since they ordered two parts it has not worked right
Just had my Kitchen Aid Microwave KHMS155LSS burn up and bellow smoke.
Thankfully, I was close by, stopped the microwave, vented the smoke, turned off the circuit breaker and unplugged it. Still the smell of burned motor, burned plastic has me concerned. Did it get hot enough to cause problems behind the drywall? So far, I am keeping a "fire watch" to make sure nothing is smoldering.
Feb 12, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
STOP HEATING FOOD SOUNDS LIKE MICOWAVE IS STILL ON. STARTED SMOKING.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Oct 24, 2010 | Kenmore 63792 Microwave Oven
Microwave starts to work then cuts out after a problem I had.
MICROWAVE RUNS ABOUT 5 SECONDS AND SHUTS OFF AND SMOKE FROM UNDERNEATH CABINET
Apr 15, 2010 | Bosch HMT9626GB Microwave Oven
Fire in Microwave Using Sensor Control for Potato
Please contact your home insurance to have the problem logged as a failure of the microwave. The insurance company will most likely help you with the smoke damage to the house and will contact the manufacturer to get their money back... there might be an issue with the manufacturing of these appliances.
Jan 04, 2008 | Amana ACO1860 Microwave Oven
Turn on, but I don't har fan and it startd smoking.
I would suspect a problem with the high-voltage inverter.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Nov 19, 2007 | Panasonic NN-T654SF Microwave Oven
Microwave Ovens Logo
583 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
