Question about Linksys Wireless-G WRT54G Router
How to hook up my router to my cable modem - Linksys Wireless-G WRT54G Router
    Problem Solver:
  • 9 Answers
Power down the router and modem sometimes this requires removal of a battery from the modem. Connect the ethernet cable from the modem to the ethernet port that is by itself on the back of the router. power on modem leaving the router off give it abot two minuets the power on the router.
Posted on Dec 30, 2010
What is dsl modem?
Yes it can. The DSL modem is hooked to the phone line or cable and a network cable comes out of it. You hook that cable to the WAN port on the rout
Aug 19, 2014 | NetGear N600 Wireless Dual Band Gigabit...
How i can setup Wifi to Thomson (DCM305R) modem?
Hello, Thanks for the opportunity to help you.
First off you modem there is not wifi but cant be hooked up to a wifi router that you can purchase from any computer store.
The modem would hook up to the router directly instead of hooking to the computer via RJ45 "ethernet cable"
The wifi router would then share that connection. You would need to set that up with some security I recommend WPA 2 encryption you will need to select a password/ or pass phrase.
In order for me to give you the How To's we would need some more information such as:
1. Brand name of router
2. Model number
Click here for some basic information on how to hook up a cable modem to a wifi router.
Thanks for using Fixya.com , We hope your found this Very Helpful.
Jan 25, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
I hooked up everything right modem to router, router to computer. but i still cant get internet to my computer. if i hook my modem directly to the compiter it works fine but not through the router
Some ISPs (Internet Service Providers) limit you to *ONE* unique computer connected through the cable-modem (or DSL-modem).
Turn the cable-modem off.
Turn the router off.
Connect the cable-modem to the router, via an Ethernet cable to the 'WAN' port on the router.
Turn the cable-modem on.
Turn the router on.
Connect, via an Ethernet cable, from one of the 'LAN' ports on the router to your computer.
Restart your computer.
You should be OK.
If not, telephone your ISP, and get them to trouble-shoot from "their" end towards your end.
Sep 20, 2010 | Linksys Wireless-G WRT54G Router
There's no place on modem to hook router
Look for Ethernet jacks. You want to hook both your computer and your daughter's laptop to the router to out ports i.e. usually on the front side. The back side of router would hook using probably another Ethernet jack to your modem.
Jul 02, 2010 | Belkin (F5D7230-4) Router (587009)
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
Nov 09, 2009 | NetGear WGR614 Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Hoe do i hook my Dlink up to a cable moden
The way mine is hook up:
1. Internet coax cable to cable modem
2. Ethernet cable from cable modem to router
3. Ethernet cable from router to my computer
Jan 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
