Question about Kenmore Dryers
My dryer runs for 6 min shuts off says pf - Kenmore Dryers
    President:
  • 1,194 Answers
Hi
PF error code indicates power failure and it seems that the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset. If the fuse tests fine then it is the main board that is bad.
Hope this will help...
Posted on Jan 01, 2011
Maytag dryer problems
There are a number if possibilities. It could be the main controller, a thermo sensor, or an issue with the power supply. The service rep has the training and tools to properly diagnose. Don't waste money in guessing. The parts are expensive to buy and try.
Aug 17, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Ge adora dryer model dhdvh52ef0ww runs for about 5 minutes then cuts off
Inside the back and the bottom of your dryer are several ( From 2 to 6 ) "overheat thermostat switches".
One of these is doing it's job really well.
These are designed to prevent your dryer from overheating and catching fire.
I suspect one of them is failing, and needs replacement.
Someone handy with electrical testing tools and mechanic's tools need to take it apart and check these to find the "bad" one.
While they have it all apart, it should need a really good cleaning inside.
Be blessed.
Mar 22, 2013 | Dryers
Whirlpool 6 cycle dryer keeps shutting off. it will start back up and run, sometimes it will finish the load and most times it will shut back off in 5 to 20 min.
vent is restricted, disconnect vent tube run dryer. Clean out your restricted vent tube with a leaf blower and make sure it is not kinked or too long, this should help Tim:
http://www.applianceaid.com/general.html#vent
Mar 11, 2011 | Whirlpool Dryers
Flashing PF?
PF STANDS FOR POWER FAILURE UNPLUG THE DRYER FOR 5-10 MINS THEN PRESS CANCEL
Oct 03, 2010 | Kenmore 72062 Gas Dryer
I got pf on maytag 3000 dryer how do i fix it?
"pf" means Power Failure took place during the cycle or the cycle was interrupted, It comes when power connection is loose to the machine, Unplug your device for 5-10 MINS, plug it back then press CANCEL button.
Good Luck and have a nice day.
Jul 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer wont turn on. PF is flashing
Aug 11, 2009 | Dryers
The dryer will not turn on its flashing pf
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Apr 15, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer
Error codes. are any of these lit? PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Kenmore 82836 Gas Dryer
Dryers Logo
64 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
