Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
EA message on unit it a manuflow split KFR 35gwz/bm outdoor unit dont start
  • 2,133 Answers
EA Outdoor four way valve defect.
Posted on Dec 30, 2010
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
Fault codes for KFR-66GW
I guess it's signs of overheating compressor, raised the temperature a bit working in the refrigeration and pull out from the outdoor unit thermistors from the copper where it is hovering and let it.
Apr 13, 2012 | Heating & Cooling
We are trying to find out what an E4 on a Celiera
Does anyone know what does that means
Mar 30, 2010 | Heating & Cooling
I have purchased 1.5 split air-conditioner of Electrolux model 18SCRDA1 from NEXT and got it installed. Till now it is working fine. suddnly we observed abnormal noise from the outdoor unit.Condenser fan...
hi there.dont touch the untit.its under warranty and if you touch the unit and try to repair it.the warranty will be non existant.im one of the serivc agent for eletrolux.
Jun 08, 2009 | Soleus KFR-18GW Split System Air...
Senville mini split codes
Put gage on low side and check the pressure running. if it is less than 125 you probably have a leak.
Apr 30, 2009 | Heating & Cooling
Senville Mini Split Error Code
thanks for your question, you will need a set of gauges on the unit to determine if the unit came precharged, if it didn't then you will need to vacuum down the unit, at least three times, after each time release a little 410a into the system them evacuate again, 410a is bad for drawing moisture, did you put an in-line filter dryer on as well ? after you find out about the freon level, then look at the name plate rating for amount of 410a needed, before adding the freon, use nitrogen to leak check the system, then weigh in the proper amount of 410a, unit should run really well after that, hope that helped, thanks again for your question, please feel free to come back if you have any more questions, thanks, mr.grzz
Jan 21, 2009 | Heating & Cooling
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
352 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
