Question about Video Game Consoles & Games
When I try to charge my PSP, the LED does not light on. After a while of the charger being plugged in, the PSP does not turn on. The PSP also will not power on with the battery taken out and the charger plugged in (I don't know if it should run on the AC adapter with the battery out).
When i'm insert my adapter to charge, the psp wont get charge, & by the way adapter got heated...which is problem adapter or battery.please help me....
Posted on Apr 17, 2011
Hi I wanted to know can I charge my PSP to my PS3?
Posted on Nov 29, 2009
How do i charge my psp battery
Plug the charger into the wall. Plug the other end into the spot on the PSP with the yellow outline. Check for an orange light. If it's on, let it charge until the light turns off. It it's not on check connection. If it's still no charging, take out the battery and put it back in. If it's still not charging remove the battery and try to turn it on. If it will no start, your PSP is bricked.
Sep 30, 2011 | Sony PSP-3000 Silver Console
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
My psp will nt charge or turn on it has been in myy locker for a while now when i plug it into my ps3 it will not charge
Try keeping your psp battery in a dry place for a day,then try charging.If this doesn't work..
Try the following:
a) Try charging using a usb cable...
c)Also try cleaning the usb port and power port or the place were u connect the charger to psp...
b) Remove ur psp battery and plug in the charger and turn on the psp... When it turns on put the battery back in (do not turn off the switch or psp when u put the battery back in)...
Mar 15, 2011 | Sony PlayStation Portable (PSP) Console
Psp 3000 doesnt want to charge
More than likely your charger is broken. If the charger has any lights on it, see if they turn on when the charger is plugged into an outlet. If the lights don't turn on, try another outlet. If the lights still won't come on, you need a new charger.
If the lights work, or your charger doesn't have any try using a different charger and see if the PSP will charge. If not, then the actual connection within your PSP is shot, or there was a short in your system.
Mar 11, 2011 | Sony PlayStation Portable (PSP) Console
I have my psp plugged in to the power cord for over a day, still not charged and it wont turn on at all. why ?? please help!!!
Probably, either the battery or the charger is busted. Try borrowing a friend's PSP charger and plug it in. The power led of the PSP should turn orange when charging. If it still does not charge, you might need to replace the battery.
Jul 13, 2010 | Sony PlayStation Portable (PSP) Console
Will not turn on Playstation PSP. Plugged into my laptop but no lights indicating charging or anything and will not turn on.
Try charging it from the wall charger .. you may just be using the mini usb plug and this will not charge the psp. hope this helps
Apr 19, 2010 | Sony PlayStation Portable (PSP) Console
I have a PSP that I charged overnight and a orange light came on when i plugged it in to the wall charger. After charging all night I went to power on the PSP and it will not power on, no green or orange...
Remove the battery.
Plug the PSP charger into the PSP.
Turn it on.
The PSP works with no battery inside.
If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
Mar 17, 2010 | Sony PlayStation Portable (PSP) Console
Psp won't charge when plugged into computer
u cant charge on a computer unless you have a charger that hooks up to it...are you sure your using a charger or are you using the cord that transfers data to ur psp! the data cord will not charge ur psp its not a charger all it does is transfer data sorry you need a charger for the psp not a data cable
Jun 18, 2009 | Sony PlayStation Portable (PSP) Console
Psp battery problem
the problem 's if u kept ur psp battrey without changing the battery it will bad , you have to wake up the battery by open the battery ,you remove the battery from the case .use solding iron to remove it after that , use ur psp changer to jump start the battery for just 5 min , after that solder it back it will start working ,,,,,,, bye
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
Switching on my psp after charging it
Please mention after switching on the PSP power LED turns on or not? ================================================= Suppose without connecting the charger when you power on your PSP you will see green light and you will get sound clear with no display at all and after 1 min: PSP will turn off automatically. then 99% it means that your PSP is bricked.
Aug 01, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
143 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
