Question about ASUS A8V-VM Motherboard
The A8V-VM MB has 4 physical connectors on the rear and risers to connect additional USB conectors. I have two USB sockets connected to one of the risers. However no matter which of the 6 sockets I use I keep getting a Windows message saying the device will work better if connected to a USB 2 port. How do I get a USB device to connect to a USB 2 port?
  • 656 Answers
The new er version of the motherbords have the usb 2.0 version if the motherboard asks for newer version i thin its better to get an usb add on card there are softwares available in market to make 1.0 to 2.0 but the result is not good
Posted on Dec 30, 2010
My mothar board are pspe.vm so i know which ram add my mothar bord 512mb ya 1 gb ya 2 gb sopart my motharbord
ASUS P5PE-VM - motherboard - micro ATX - i865G specifications
General
Product type (AE)
Motherboard
Form factor
Micro ATX
Width
9.6 in
Depth
7.6 in
Compatible Processors
Pentium 4 , Celeron D , Core 2 Duo , Pentium D
64-bit Processor Compatibility
Yes
Mainboard processor socket
LGA775 Socket
Mainboard / Multi-Core Support
Dual-Core
Chipset Type
Intel 865G / Intel ICH5
Data bus speed
800.0 MHz
BIOS type
AMI
Storage key information
Serial ATA-150 , ATA-100
Power connectors
4-pin ATX12V connector , 20-pin main power connector
Processor
Installed Qty (Max Supported)
0.0 ( 1.0 )
Memory
Cache Memory Type
None
Supported RAM Technology
DDR SDRAM
Supported RAM Integrity Check
Non-ECC
RAM Installed ( Max )
0.0 MB / 2.0 GB (max)
Supported RAM Speed
PC2700 , DDR266/PC2100 , PC3200
RAM Features
Dual channel memory architecture , Unbuffered
Video
Graphics Controller
Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0
Audio
Audio Output
Sound card
Signal processor
Intel 865G
Audio codec
AD1988
Sound Output Mode
5.1 channel surround
Telecom / Networking
Modem
None
Networking
Network adapter - Marvell Yukon 88E8001 - Fast Ethernet , - Ethernet , - Gigabit Ethernet
Features
BIOS Features
SMBIOS 2.3 support , ASUS EZ Flash , WfM 2.0 support , ASUS MyLogo , Hyper-Threading Technology , DMI 2.0 support
Manual Settings
CPU frequency
Sleep / Wake Up
Wake on LAN (WOL) , Wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall) , Green Edition , CrashFree BIOS 2
Expansion / Connectivity
Expansion Slots Total (Free)
1.0 AGP 8x - LGA775 Socket , 1.0 Memory - DIMM 184-pin , 3.0 PCI , 2.0 Processor
Storage Interfaces
Intel ICH5 : ATA-100 - connector(s): 2 x 40pin IDC - 2.0 device(s) , Intel ICH5 : Serial ATA-150 - connector(s): 2 x 7pin Serial ATA - 4.0 device(s)
Interfaces
1.0 x Audio - RS-232 - Mini-phone stereo 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - IEEE 1284 (EPP/ECP) - Mini-phone stereo 3.5 mm , 1.0 x Keyboard - Line-out (center/subwoofer)/line-in - 4 pin USB Type A , 1.0 x Audio - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Serial - Generic - 25 pin D-Sub (DB-25) , 1.0 x Mouse - Line-in - 6 pin mini-DIN (PS/2 style) , 1.0 x Hi-Speed USB - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 4.0 x Audio - Line-out (rear)/microphone - 4 pin MPC , 1.0 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1.0 x Storage - Floppy interface - 9 pin D-Sub (DB-9) , 1.0 x Audio - RJ-45
Additional connectors (optional)
4 x Hi-Speed USB
Miscellaneous
Compliant Standards
RoHS , Plug and Play
Hope this helps,
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | ASUS P5PE-VM Motherboard
I want A8V VM SE ASUS Motherbord Driverr
Here is a link from the manufacturer: http://support.asus.com.tw/download/download.aspx?model=&SLanguage=en-us
-Select Motherboard in the first field; -Select Socket 939 in the second field; -Scroll down and look for A8VM SE motherboard; -Press search and and you will be asked about the operating system; -Select the OS and then press search again.
If you need further assistance, just leave a comment.
Apr 20, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
HOW TO CONNECT FRONT SIDE USB PORTS
*********** board as option to connect the front usb ports check where the ports are available, insert the cable your front usb port will be work.
Apr 05, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
My pc audio isnot coming pl do sugest us how to down load model asus A8V - VM SE E2928
http://www.driverstock.com/ASUS-A8V-VM-driver-download/6-9-10211/index.html.only drivers I could find hope this helps.
Mar 12, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
USB wiring on KT4AV MS-6712 Ver 10A motherboard
Open the link provided; http://www.directron.com/installusb.html
You will need to scroll down until you see, Intel Standard USB header Layout. Also see: Common USB case header connectors.
Hope this is what you're looking for.
Cheers'
Mike
Feb 07, 2010 | Intel Motherboard
I'm installing a card reader that has 5 wire connector tto the mb. The old card reader has a 7 wire connector that fits the mb. Its an Asus m2n68-vm. Thanks
These card readers normally fit the auxiliary USB socket on the motherboard. They usually take up all nine pins, four on one row and five on the other with a 10 socket plug. One pin missing on the end of a row.Such card readers have an additional external USB port as well as card reader slots. If it is just a straight five pin plug but with four wires it just fits over one side of the nine pin USB socket on the motherboard. The black wire goes at the end with the missing pin.
Mar 29, 2009 | ASUS P4P800SE Motherboard
ASUS A8V-VM Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
