Question about Activision Tony Hawk Ride for Xbox 360
The board doesn't connect to the Xbox360. the point is in the box wasn't any wireless USB connector and the xbox doesn't have a connect switch as it is written in the informations papers. Try pressing the buttons as usualy connect a new remote controller.
  • 112 Answers
Usually xbox 360 accessories connect without a usb connector. They sync with the console like a regular controller would.
Please Rate.
Posted on Dec 30, 2010
I have a sony KDF-50E2000 When I connect my xbox360 I get like ghosting on tv.
Have you connected the XBox using the component cables ? If so there is a small box on the connector cable with a switch labeled HDTV. Try changing the position of the switch.And I hope the XBox is not from another country where the color system is different from yours ( Europe is PAL and USA/JAPAN is NTSC ).
Mar 10, 2011 | Sony Televison & Video
Cant connect to xbox live
Make sure you are connected directly to the modem if you are using the usb cord .If you are using the wireless adapter make sure the code u imputed corresponds with your own.
Nov 15, 2010 | Microsoft Xbox 360 Console
For my xbox i have a wireless connector and wireless interet in my house but the xbox wont connect to live
Will it not connect, like it gets to the point to connect and nothing or...? Also, check the actual wireless usb connector led light. Is it red or green? These things have a tendency to get shorts in them. Try wiggiling it around and see if the light flickers off and on.
Jan 31, 2010 | Microsoft Xbox 360 Console
Xbox connected through network cable to pc ! what do i need to perform on pc through my wireless usb port connected to go online
If you are running Windows Vista on your PC here is how you can route your XboX360 through your PC/Laptop in order to get on Xbox Live Wirelessly:
1. Set up a Static IP address in Vista. Go to Start -> Control Panel -> Network & Sharing Center -> Manage Network Connections
2. Right-click on Local Area Connection and go to Properties
3. Double-click on Internet Protocol (TCP/IPv4)
4. Set the option to "Use the following IP address"
IP Address: 192.168.100.1
Subnet Mask: 255.255.255.0
Default Gateway: blank
5. Just to be safe, also set the options to "Use the following DNS Server Address"
Preferred: 208.67.222.222
Alternate: 208.67.220.220
(You may use your ISPs DNS entries also, these are just the OpenDNS ones that should work for everyone)
6. Under the "advanced" tab, you need to check "Allow other network users to connect through this computer's Internet connection."
7. Right-click on your wireless connection, go to properties, click the "advanced" tab and check the same box to allow other users to share the connection.
8. On your Xbox360 go to the network configuration menu and enter the following settings:
IP address: 192.168.100.5
Default Gateway: 192.168.100.1
DNS1: 208.67.222.222
DNS2: 208.67.220.220
Now you should be able to get on the internet with your Xbox as it will be using your PC/Laptop's wireless connection.
Jan 04, 2010 | Microsoft Xbox 360 Console
I am using this adapter to connect to my WGT624v3 router. Both netgear. My computer is connected to my xbox360 and sharing its connection with the console. I can share the internet for xbox live, but when...
If you are using a wireless connection you could have a weak signal, move the router or the XBox to get a stronger signal.
You could be getting an interference with other wireless routers/access points in your area. Check the broadcast channels of the various routers/access points in your area and select a channel that is not being used for your wireless router.
Sep 30, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
My xbox360 internet port is broke so i cant play xbox live or system link
the Wireless is usb so if the is broken Ethernet port is broken u can get the wireless if you have a wireless router
May 15, 2009 | Video Game Consoles & Games
Cannot connect my modem to xbox live
Try disconnecting your Xbox from the modem, turn both off, wait 60 seconds.
Reconned the Xbox to the modem, turn the modem on, wait 3 minutes, then turn your Xbox on. That should work.
Dec 28, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
MTU fail
ok well I found a fix but it may not be simple. anyway, i got my xbox360 to work off of my girlfriends laptop by feeding internet to the laptop from the cable modem via usb and then from the laptop to the xbox360 via ethernet. just right click usb connection in network connections and click sharing tab, then activate sharing and tell it to share connection with lan connection... you can also share through wireless if your xbox is wireless. I tried running all this through a dsl wireless router and a basic hub and both of them gave ip address and mtu errors... good luck
Nov 10, 2008 | Microsoft Xbox 360 Console
Xbox live connection
three is the network
connect and install three usb modem
connect xbox to pc with ethernet cable
then start right click my network places and go to properties in network connections right click 3 usb modem then properties then advanced, tick the box allow other network users' then okay
now connect 3 3g device turn on xbox and BINGO !
Dec 15, 2007 | Microsoft Xbox 360 Console
Activision Tony Hawk Ride for Xbox 360 Logo
773 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
Zhenya Ogorodnikov
dj ese
Level 1 Expert
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
