Question about Maytag Atlantis MAV9501E Top Load Washer
Not working the cold water valve does not come on. Only hot water comes out. Switched the plugs and cold water came out but no hot.
  • 413 Answers
Disconnect water hoses from machine. Inspect the filter screen on the cold and hot water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove debris or water flow is still slow, replace valve.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 08, 2008
No cold water will come in
make sure cold water is turned on first.lf it is then shut off cold and hot water to washer. take off cold water hose at water valve and check to see if the screen in the water valve is plugged. if it is not you will have to replace the water valve. good luck.
May 26, 2012 | KitchenAid KAWS850LE Top Load Washer
Setting is on cold/cold, but only burning hot water is coming out. When I switched it to warm/cold, it got a little cooler but still not cold. The hot/cold setting is also just warm water, so the hottest...
This seems to me to be that the hoses are connected backwards. It matters very much which hose is connected to which inlet. Make sure that the hoses are on Hot to "H" and Cold to "C" on the machine.
Aug 29, 2011 | Admiral AW22 Top Load Washer
The machine will only fill with hot water. I have switched the feed lines and even turned off the cold water and gotten the same result. Is this a bad solenoid?
Your COLD inlet valve is faulty. By swapping the hoses you have cold water coming in via the hot inlet valve. However, most machines will only rinse with cold water, but your machine thinks the water is hot. So...it won't rinse! Replace the cold valve or change the wires from the cold to the hot valve...Some electronic machines can be damaged by doing this. Non electronic machines could be ok...Good luck....Nomess
Apr 23, 2010 | Washing Machines
Kohler shower valve (hot/cold switched)
Just had this same thing, on this exact faucet. If you still have the manual, it has instructions on how to rotate the valve for back to back installations where one shower has the hot/cold reversed. Our contractor got ours in backwards the first time and I had to call and have them come out and rotate the valve this morning.
Dec 19, 2009 | Kohler Forte entertainment remote valve...
NO COLD WATER
if you cleaned the screen in the valve of the washer and it still does not work then you need to replace the valve. the valve on the cold side probably has a piece of sediment in it not allowing it to open.
Dec 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Cold water not coming on in cold mode
YES.Just replace the valve.it comes in one piece.
Dec 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Cold water valve won't turn on to fill washer
either the valve has failed or the water line screen is blocked.
Aug 31, 2017 | Maytag Neptune MAH5500B Front Load Washer
Should the washer be hot after the rinse cycle?
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Maytag Atlantis MAV9501E Top Load Washer Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
