Question about Lands Phones
I HAVE BOUGHT 2 NEW BATTERIES IN ONE MONTH AND MY ONE YEAR OLD PHONE WILL NOT HOLD A CHARGE
I have the same problem
Posted on Aug 10, 2008
Why wont my mobile phone battery hold a charge
It is possible that the replacement batteries are defective.
Jul 11, 2016 | Samsung Galaxy Cell Phones
I have a Samsung notebook np n135 for 2 years. I have replaced battery twice now and it doesn't hold a charge for more than one hour and dies. What else could be wrong with it?
If you leave the old type NiCad batteries on charge all of the time, they will barely last a year. Run the battery down at least once a month.
Nov 16, 2013 | Computers & Internet
14.4 volt cordless drill --- yelloow and green light on lo0nger than 15 minutes, cannot find user manual.
The battery will no longer take a charge. Time for a new one. I had 2 like this in the last month. The batteries where 5 years old and been charge for over 800 cycles each. Age and cycles will wear them out.
If the tools is still good jsut get new batteries. But check the prices. I just bought a new drill and saw set for $90 and 2 new batteries were $60. I got a new set, since the drill was 8 years old and worn out.
Jun 30, 2011 | Ryobi Drills
Batteries don't hold charge
This is frequently caused by corrosion on the battery contacts and the contacts inside the radio. Remove the batteries and wipe all the contacts firmly with a clean dry cloth. Heavy corrosion may require cleaning with a fine wire brush, steel wool. or sandpaper. After the cleaning, make sure that there is no residue in the battery compartment, then replace the batteries and give them a good charge. If this does not work, it may be time for new batteries -- especially if yours are more than a year old.
Bill B
May 04, 2010 | Uniden GMR648-2CK (22 Channels) 2-Way...
I have uniden Dect 6.0 dual handset. The second handset will not hold a charge even after several days in the base. The battery indicator says full but will not last long enough to even dial a number. The...
Is the phone under warranty?
You should check that the battery is a genuine Uniden one. (Check them all).
From personal experience - I had the same problem with a phone I bought (supposedly) brand new - though mine would last about 10 minutes. The batteries which came in the box were not genuine Uniden batteries. I had to buy new ones direct from Uniden (to be sure) - and no problems since..
I have since been told that sometimes the original batteries are stolen and replaced with cheap nasty ones - before they even get into the shop.
Same thing can happen with computer software - they make copies from the original cd. Then they just need a vacuum packaging machine to make it look like it has never been used.
Mar 28, 2010 | Uniden DECT 6.0 Cordless Phone ID
The batteries does not hold the charge.
A few solutions for you:
1) The batteries that you are using may have reached their end of life.
2) You are using higher capacity batteries in a charger that was designed for lower capacity batteries. The charger may be a 1 hour charger that was designed for say, 1500 mAH. If your batteries are 2000 mAH, then after the same hour, the batteries may not have a full charge, and will be damaged if this were the case, and the practice continues.
3) You are using a combination of batteries and charger that isn't compatible. For example, NiCD chargers cannot charge (usually) NiMH batteries, and vice versa.
4) There is always some drain by the batteries themselves, just being rechargeables. Though, this is usually on the order of 5-10% per month, and probably is not the issue.
I would put my money on saying that the batteries are worn out. Try a new a new charger / battery combination. If that works, then either the old batteries or old charger are defective.
Sep 15, 2009 | Canon PowerShot A590 IS Digital Camera
Viewty's battery loses charge very quickly
with rechargeable batteries you have to fully charge it up then completely run the battery dead for the first 3 or 4 times this is what extends the battery life. I have had an LG viewty for 16 months and only charge my phone twice a week. this is a golden rule for all rechargeable batteries
Aug 19, 2009 | LG KU990 Viewty
UNIDEN EXP7900 NEW BATTERY CHARGED, GREEN STATUS LIGHT ON, BUT CANNOT GET A DIAL TONE. THIS WAS AFTER THE PHONE HAD BEEN UNPLUGED FOR ABOUT 3 DAYS.
I have a Uniden DECT 6.0, 2 handset phone. I charged the batteries twice for at least 15 hours. I usually unplug the base at night and plug it back in in the morning. Both the phones lose their charge overnight. My old Uniden phone never lost its charge. Is this because the new batteries are smaller than the old ones? Are the batteries bad? I bought this phone from Ebay who said this was a brand new phone, box never opened. Thank you.
Nov 16, 2008 | Uniden Lands Phones
Out of range, buttons don't respond, battery won't hold charge
when you have a problem with anything under warranty, you take it back for new units or a refund and anything under 12 months old is under warranty
if you have lost the receipts get a copy of your bank statements as that shows where it was bought , how much it cost and when
That is a legal document to trigger a warranty action or refund
Mar 10, 2017 | Uniden DECT 6.0 Cordless Telephone...
Phone discharges battery
Well take it to the shop you bought it from and you might have to have kept the receipt and they will send it off to the specialists ,
it is a common thing with motorolas and batteries should last at least 1 year anyway hope i helped :)
Oct 16, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
73 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
