Question about Acer P235H LCD Monitor
Dear Sir/Madam, My Acer deskdop is not working it's power light is coming so dim and the desktop is blank please let me know what to do
4 Suggested Answers
tantong
  • 138 Answers
SOURCE: Blank ACer X221W Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went dim and blank, you have to check if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Mar 06, 2008
budmrtn
  • 11361 Answers
SOURCE: X241W Acer monitor: getting blank screen. When
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 16, 2010
nidhishg
  • 92 Answers
SOURCE: Sir/Madam im shiva from chennai
Dear Sivakumar,
please try to remove and plug VGA cable back again to the monitor. and press the menu button in front of monitor if it doesn't giving any message in monitor it means that the control card inside the monitor is faulty.for fixing that you have to contact your local service center.
Thanks
Posted on Jun 18, 2011
My acer e1-510 laptop keeps on coming up with pasword hint 77421910 and my password will not work. any ideas.
Hi Sir/Madam
R u tried with external usb keyboard....
Most of the cases it will be keyboard problem...Disconnect the laptop keyboard and connect external keyboard..ur problem may solve.
Sep 21, 2017 | Acer Computers & Internet
Hi sir/madam: my laptop
combine these keys to deactivate num lock
FN+Num Lock
Fn should be close to CTRL button and Num lock might be on the top right side..
easy
Sep 07, 2013 | Computers & Internet
Respected sir/madam I have a acer aspire 4520 laptop and not powering on at all
Please remove the battery from laptop and try to power on with AC Power only. If the laptop is powered on then there may be problem with battery. If the laptop is not power on, please check the Power adpater dc voltage with multimeter.
Jul 11, 2011 | Acer Computers & Internet
Sir/Madam im shiva from chennai , i have acer AL1713B lcd monitor , but my prob is when i connect the power cable the led light is working , but display is not working. how can my solve this prob?
Dear Sivakumar,
Thanks
Jun 18, 2011 | Acer AL1713 17" LCD Monitor
Dear Sir/Madam, My desktop Acer Aspire M1641 Windows Vista home premium, refuses to start up. The computer started to malfunction at intervals but given time rectified itself, however, now it has...
Unplug the power cord then press and hold the power button for 20 seconds. Plug the power cord back in and press the power button. Did you see any lights or hear any fans? If not, the power supply is probably bad.
Mar 06, 2018 | Acer Aspire M1641-U1521A PC Desktop
TV not working
The red light flashing is an error code. Count the number of flashes before a long pause.
Mar 22, 2010 | Samsung Electronics - Others
Power comes on but screen blank, won't boot or anything
You have to check with RAM sir , if you know to remove the side cover of the pannel remove it by unscrewing the back side screws , you can find the RAM which is in green colour fixed vertically in the motherboard , if you remove it and fix it again you may get , have to release the white color notch to remove the RAM , thank you RAM will be like this only5620f69.jpg
Oct 30, 2009 | Sitoa Acer Desktop with 160GB HD Vista Bus...
Dear sir/madam i want to
go to proprofs.com or comptia.com
Aug 31, 2009 | Acer Computers & Internet
No signal on the screen
Did you check if you connected the singal cable properly? If the signal cable drops, you can reconnect it again and see if it works
Nov 23, 2007 | Fujitsu Siemens Celsius 460...
Acer P235H LCD Monitor Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
