Question about Frigidaire Refrigerators
My power was out for about 12 hours. Now it is back on and I have a side by side fridge/freezer. everything defrosted in my freezer and it no longer makes ice. the fridge half seems to still be working
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
it takes about 24 hours to get back in shape.. i would wait and see, your freezer should be at Zero
and refrig at 38 or so
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
Fridge stops working and warms up for half a day then will cool back off and start working for a day or a few days. When it warms up everything in the freezer defrosts but will then refreeze a day later...
Check your defrost thermostat in your freezer access panel. Your defrost timer could be faulty, Your defrost timers ussually run for 12 hours and defrost runs for 30 minutes. That being said that is why I believe your timer is getting stuck on run and then eventually it finally gets unstuck and goes into defrost. Eventually it will get stuck in one place or another.
Aug 27, 2010 | Frigidaire FRS26H5AS Side by Side...
Back of freezer is frozen but everything in the freezer is thawing out.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 20, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
FREEZER SIDE TOO MUCH ICE FRIDGE SIDE NOT TOO COLD
If it has ice buildup on the back wall inside the freezer, it appears to have a defrost problem. Unplug it, put your food in another unit (or ice chests), open the freezer door and let it thaw out overnight for at least 12 hours or more, or until all the ice has melted from *behind* the back wall. Then close the doors and run it for 4 hours and check to see if the fresh food side is cold. If it is, call a repairman to fix the defrost problem. That could be a burned out heater, terminator, or defrost timer depending on your exact model.
Jan 03, 2010 | Whirlpool Refrigerators
AMANA FRIDGE ARB190RCW FREEZER AT THE BOTOM. FRIDGE IS RUNNING BUT NOT COOLING. FREEZER BACK WALL FULL OF FROST
Switch off unit for 12 hours and do a proper defrost. once all ice is gone, switch back on and take note if evaporator fan is working.
Oct 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
GE Profile Fridge/Freezer defrosting
You will need to replace the electronic mother board which is located in the back of the refrigerator,Inside rectangular cover near the bottom left.
Feb 28, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
FRS24zrh Side by Side Fridge was not cool enough then freezer started warming up, defrosted everything, vacuumed underneath, worked fine for about 12 hours and now seems to be warming again
I had the same sort of problem. Found that the freezer would not completely defrost on each defrost cycle. Replaced the defrost thermostat and solved the problem.
Hope this helps.
Jul 23, 2008 | Frigidaire Refrigerators
Refrig/Freezer not getting cold
If there is frost on the back wall of the freezer section a defrost is required. Defrost is normally automatic on a timed cycle. If you have frost and you know it is because of the door being open to long with the refrigerator running it could clear the coil automatically in the next 12 hours of operation. If it does not clear the frost from the coil inside the back wall you may require service to check out the timing device, heaters, and defrost thermostat.
Mar 07, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
