Back to:
Tags:
IBM ThinkPad A21m 2628 PC Notebook
Laptop Cannot Connect To Internet
posted by JoshuaWolf on Jul 07, 2008
I have a Cable ISP for my home desktop, and everything on there is fine, but my laptop has a wireless internet setup. Everytime i try to add a cable set-up, it says the system should already accept and/or run with a cable connection, and then cancels out of the internet wizard. is there any way to fix this so that I can go online with cable on my laptop? (without my Xp disc being needed, because it's "somewhere", just not sure where.)
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 07, 2008
Thanks for Trying (70)
Pyrhyc
Rank:Guru Guru
Rating: 86%, 1013 votes
You shouldn't have to run the setup wizard. You should be able to plug it in and click on internet explorer and it will connect. This is built into the operating system. If it doesn't do this, then you will need the disc to run a system repair.
Rating Locked! (?) JoshuaWolf has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Laptop Cannot Connect To Internet:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
I wish to connect my Asus Notebook to the Yamaha reciever...
PC Laptops
I have had a pink line running vertically down my laptop...
PC Laptops
I am having bsnl broadband connection with Siemens C2110...
PC Laptops
My screen on the left has a bright pink color all the...
Having read numerous requests on this Thinkpad failure,...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
