Question about Staples ID Armor SH2836ID2836 Shredder
I have an ID-1050LBKX. I turn it on, the Power light is lit, but it won't shred, won't run at all. The bin is empty and the last thing that was shredded was a single piece of paper. I just oiled the access entry and tried it again. Nothing. Loraine
3 Suggested Answers
  • 300 Answers
SOURCE: after shredding a piece of paper the machine wont
Please check to make sure the paper sensor is not blocked in some way.
This usually happens if there is any sticky tape on the paper or envelope shredded.
Posted on Apr 01, 2011
SOURCE: I have an ID Armor
I think it is necessary for you to take it apart. Is your shredder designed to handle plastics such as CDs? Try these steps and see if it will do you any good.
Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers. Look for small debris from the CD which may be stuck inside the shredding/feed mechanism.
Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small plastic scraps that may cause a jam.
If the cleaning failed and your shredder still wont start. You need to have the shredder serviced as the damage may have extend to cause a mechanical failure on the device.
Hope this helps.
Posted on Sep 20, 2011
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
My shredder worked fine but now when I turn on it does not stop running and does not shred paper ?
Most shredders will have a shred and a reverse setting. Is it running in reverse? Has the bin been emptied? With the power off, you can remove the bin and manually pull excess shredded paper jammed in the cutting heads -watch out, sharp metal . Once cleared run single sheets for the first minute to help clear rollers.
Jan 05, 2015 | Shredder Office Equipment & Supplies
Embassy shredder open door light won't go off after emptying bin. Therefore no shredding
The shredder probably has some kind of switch or sensor that detects that the bin is in its correct installed position. The interlock may be broken or blocked by paper shreds. An inspection inside the bin recess may reveal the cause so that it can be corrected.
Oct 19, 2014 | Office Equipment & Supplies
Staples titanium shredder
Sometimes the sensor gets blocked by pieces of shredded paper. Unplug the unit and remove it from the paper bin. Turn it upside down and see if there are any "stray" pieces of shredded paper hanging on the unit. Remove the stray and replace the unit onto the bin making sure it is properly seated. If that is not the problem, try "tamping" the shredded paper into the bin and by doing so, giving the machine more room for the shredded paper. If neither of these help, refer to your owner's manual to see what recourse you may have.
Jan 08, 2014 | Office Equipment & Supplies
We missed emptying out the machine, now we are not able to open the drawer. What can we do?
Try shaking the machine to lower the cuttings in the bin. You might have to pull really ******* the bin to remove it. Be careful you do not break handle on the bin. The machine should have stopped shredding when the bin full sensors were activated, if they did not , then you have bad sensors in the unit and they should be replaced.
Aug 30, 2011 | Fellowes SB95C Cross-Cut Shredder
Need owners manual for B&D paper shredder Model BD-10P. i have a jam
Hi and welcome to FixYa, I am Kelly.
The manual is little help but you can find it here:
http://media.homedics.com/IBs/bds/BD-10P_IB.pdf
Troubleshooting
If you have a problem with your shredder, check the symptoms and remedies below.
If you cannot solve the problem this way, contact Black & Decker paper shredders
Customer Service.
Do not open shredder head to attempt repair: It could expose
you to electric shock and will void your warranty.
- Check to see if bin is full. If bin is full, empty bin and
replace. Follow instructions under maintenance.
- Oil cutting cylinders.
Shredder squeaks, grinds or runs
below capacity.
- No action required. This is a self-Shredder continues to run for cleaning function.
1 or 2 seconds after shredding
has been completed.
Symptom Remedy
- Make sure shredder is plugged in.
- Make sure power switch is in "Auto" position.
- Make sure bin is fully closed.
- Check to see if either bin is overfull which could result
in a jam. If so, empty.
- If you are unable to clear the jam, turn off and unplug
the shredder. Slowly and carefully pull the remaining
paper out. Forcefully removing the paper is likely to
cause irreparable damage to the shredder.
Shredder does not start or stops
while shredding.
Paper jams.
HOW TO GET SERVICE:
Visit our website at www.blackanddeckershredders.com or call the toll free customer
service line at 1-800-297-5028.
® SKU #BD-10P
Product Information
This product is designed to shred paper, staples, small paper clips, credit cards, CDs and DVDs.
It is not intended to shred large paper clips, continuous forms, adhesive labels, transparencies,
newspaper, cardboard or any other plastic other than credit cards. Using it for these purposes
is likely to cause irreparable damage. Please do not attempt to shred more than 10 sheets/1 CD
or DVD at a time. Shredder should not run more than 200 sheets/50 disks continuously. Items
should be centered and unit will begin and end shredding automatically. All disks should use
specific entry as noted on your shredder.
Maintenance
It is important to empty the waste bin regularly to ensure the smooth operation of the
cutting cylinders. The shredder will not operate when the bin is full. Regular oiling
is also necessary for proper performance. It is recommended to use the shredder oil
every few weeks.
Maximum running time: 3 minutes
Automatic cool-down period: 30 minutes
Voltage: 120
If you have any questions regarding the product, please feel free to
call toll-free 1-800-297-5028
Thanks for Choosing FixYa,
Kelly
Apr 07, 2011 | Black & Decker Garden
SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Nov 11, 2009 | Fellowes DM15C Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Techsolutions TS-8000 runs continually when switch is on. Normally you need to feed it to start is in the on position
I have a TS2500 and it behaves in a similar fashion. It sounds like you may have a paper jam keeping the paper sensor switch turned on. The first thing to do is make sure that the container that collects the shredded paper isn't full. Everytime I fill mine up I have this problem. Emptying the bin and pulling the shredded paper from the bottom of the unit usually allows it to automatically shut off. If that isn't enough, make sure that you don't have a paper jam in the cutter rollers. The most important thing you can do is make sure the unit is unplugged before doing anything with the shredding mechanism.
Hope this helps.
Dec 09, 2008 | Tech Solution TS-4500 Shredder
Staples ID Armor SH2836ID2836 Shredder Logo
82 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
