Question about Refrigerators
When you close the fridge door, the freezer door pops open. At one time, the door habdles were reveresed to make it a right opening door set insted of left. Help...
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
your gaskets/seal are just getting weak, and need to be replaced.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
GE refrigerator model #LTC19340ST freezer door not sealing
That is a common problem with over-under units. You can clean or replace the door seal or, tilt the unit back a TINY bit. The door pops open because there is a common airway from the freezer to the fridge. When the fridge door shuts too fast, it pushes a lot of air into the unit. It needs to go somewhere so, it pops the freezer door open. If you shut the freezer hard enough, you will be able to pop the fridge door open.
Jan 20, 2013 | LG LTC19340ST 19.0 cu. ft. Top Freezer...
My amana bottom freeze refridgerator door in opening a little when the top door is closed. do i need to adjust the screws or is it something with the seal?
raise the front legs so the machine is tilted back a little,this will help the top door close easier,also most likely you have nothing heavy on the door itself,all a fridge does is move air,the evaporator coil gets cold and the evap. fan blows cold air from the freezer into the fridge side and the air keeps circulating,when you shut the top door it's pushing the air down into the freezer and popping the door open,like i said raise the front legs a little and put stuff on the freezer door so it has some wieght to it and it won't pop open.hope this helps salde
Jul 24, 2012 | Refrigerators
Freezer door pops open
when you close the fridge door you create pressure in the fridge and the freezer door may pop open, close it more softly. or there may be stuff pushing against the inside of the freezer door
Mar 05, 2012 | Maytag Refrigerators
Every time the refrigerator door is closed, the freezer door pops open. How can we better secure the seals?
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Dec 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Freezer door won't stay shut
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
Jan 18, 2009 | Refrigerators
Doors not sucking closed
This is not a fault but it is a design problem that cannot be resolved, the problem occurs because between the fridge and the freezer there is an air duct to allow the freezer air to be blown into the fridge however when you close the fridge door this forces the air back into the fridge, the result is that it is forced into the air duct and pressurises the freezer or visa versa and pops the door open to allow the compressed air to escape. soory no cure to this one. Regards Advisor
Sep 01, 2007 | Kenmore 64702 Top Freezer Refrigerator
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
