The refrigerant from my outside althema unit leaked out completely and my underfloor heating is no longer functioning. The unit was accidentally punctured when attempting to remove ice which develops in very frosty weather from the base of the unit. Does this mean the entire unit will need to be replaced, is this a major job and does a replacement unit come with refrigerant already installed? IS this an expensive repair? I am in ireland
  • 2,133 Answers
Before giving solution, my humble advise not to try to remove ice by harmer or any tools. With help of heat torch you can remove. Now the solution is :
No need to replace complete set. Yes little costly expensive. Call repairman, he will arrest leak by brazing material and then vacuuming and gas charging.
Is it helpful?
Posted on Dec 30, 2010
Tip
Refrigerator Trouble The Outside of Refrigerator Hot
<p>There are many reasons why the <b>outside of a refrigerator can be hot</b>. Some of these are for good reasons and some of these can be cause for concern because they are <b>signals of trouble</b> or impending trouble.<br /> <p><br /> <br /> <p>First let's look at the good reasons for why the <b>refrigerator outside cabinet</b> could be hot.<br /> <p><br /> <br /> <p>Because of the cold inside of the <b>refrigerator</b> the out side of the <b>refrigerator will sweat</b> or even get frosted if the metal surface is not heated. To keep the sides heated there are either parts of the <b>condenser coil</b> or <b>electric heating elements</b> in the sides of the unit. The center post of <b>side by side refrigerators</b> is heated by <b>electric heating coils</b>. These feature keep <b>refrigeration units</b> dry, especially in <b>warm humid climates.</b> Most of these features can be turned of and on by using the <b>energy saver switch </b>or the<b> condensation switch</b>, whatever the unit maker has chosen to call it.<br /> <p><br /> <br /> <p>Now, if your <b>refrigerator is hotter then normal</b> on the outside, it can be an indication that your are either having problems or about to have problems. These problems can be simple or they can be serious.<br /> <p><br /> <br /> <p>If you have <b>left the door open</b> and the refrigerator has had to run for a long time then the sides could get hotter then normal. <br /> <p>If you have just placed a <b>large amount of hot food</b> in the refrigerator then the extra run time to cool the food can cause it to heat up.<br /> <p>If the <b>door seals are bad</b> then the <b>refrigerator will run mor</b>e and cause <b>excess heat.</b><br /> <p><span>If your</span><b> condenser coils are plugged with dust </b><span>bunnies so big you can name them,</span><b> </b><span>the heat is not being removed by the </span><b>condenser coil</b><span> and so the sides are getting too much heat and the </span><b>refrigerator is running too long</b><span>, causing a compounding of your problems.</span><br /> <p><br /> <br /> <p><span><span>Refrigerator </span></span><u><a href="/../support/r4024657-refrigerator_condenser_coil_cleaning"><span><span>Condenser Coil Cleaning</span></span></a></u><span><span> Refrigerator Repair</span></span><br /> <p><br /> <br /> <p>These are the simple things... the effects are either temporary or can be fixed easily.<br /> <p><br /> <br /> <p>Now for the problems that can cause too much heat but are much more difficult to fix.<br /> <p><br /> <br /> <p>The <b>condenser fan has gone bad </b>and stopped causing the condenser coils not to do their job and the excess heat to be transferred to the sides of the refrigerator. If the <b>condenser fan is not running</b> but the <b>refrigerator compressor</b> is, then the fan motor will need to be replaced. This is not a real hard job, but it is tight quarters in there and it will take some time and a lot of patience for most <b>refrigeration units</b>.<br /> <p><br /> <br /> <p>The worst case is if the<b> refrigeration system</b> of your <b>refrigerator has developed a leak</b> and because of this the <b>compressor is running longer then normal</b> and also is not cooling the unit properly. Because of the higher temperatures inside the refrigerator and the continued heat from it cooling a little bit the sides or especially the<b> electrically heated parts, </b>like the center post<b>,</b> will heat up rapidly and get much hotter then normal. To fix this problem will require a licensed tech. Who can identify the leak and repair it. Then <b>vacuum the refrigeration system</b> and recharge it again.<br /> <p><br /> <br /> <p><a href="/../support/r4588788-refrigerator_or_freezer_not_cooling_or">http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or</a><br /> <p><br /> <br /> <p><br /> <br />
on Jan 13, 2011 | Refrigerators
My radiant floor heating suddenly stopped working. Wall thermostat is functioning normally. GFCI test is working fine. What can I check next?
Monica, There might be a break in the wire mat, you or a electrician will have to check with a digi multi meter.
Links below show how.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test underfloor heating with multi meter
How do test the resistance of my electric underfloor heating system
http://www.suntouch.com/support/troubleshooting
Testing underfloor heating
Mar 02, 2016 | Heating & Cooling
Aube th132 problems
The unit is not talking to the sensor. It is most likely the sensor.
Mar 13, 2014 | Hardware & Accessories
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
The temperature is going high and is runing all the time
Hi mh_petrovici - When doors are opened too often or too long, warm air enters the refrigerator causing it to run more or when the room or outside temperature is hot, it is normal for the refrigerator to work longer under conditions. Temperature control may be set too cold (normally found in refrigerator section), set control to warmer setting until refrigerator temperature is satisfactory. Allow 24 hours for temperature to stabilize completely. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Check and see if the condenser is dirty. A dirty condenser blocks air that dissipates the heat that the condenser removes from the unit. Clean the condenser every 6 months and more if you have animals in the house.
Nov 23, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Have RHOSS heat pump showing E01
Different manufacturers use different codes, as I am sure you have figured out. Most of them that I have run into E-01 means the inside and outside units are not communicating. One is without power or there is a broken or loose wire.
Jul 17, 2010 | Heating & Cooling
New inverter reverse cycle leaking water out the front of the unit. Its 44 degress outside, could this be the problem?
Is it leaking out of the evaporator(inside unit) or condenser?
If it is leaking from the outside unit on defrost then it is normal, if it is leaking from the inside unit then you have a blocked condensate drain tube!
These units defrost from time to time and is normal, it is actually melting the ice that can form on the condenser when it is cold enough outside, it has to initiate a defrost cycle so that air can flow through the condenser again after the cycle is complete.
Then it will return to normal heat pump mode, this is assuming that you have a heat pump.
Jan 11, 2010 | Fujitsu Electronics - Others
Evcon AC (heat pump) leak in indoor coil
Most refrigerant leaks can be repaired. However, if the leak is between the aluminium fin plates, I would have to agree that it should be replaced. They are correct that you cannot after fifteen years find either an indoor or an outdoor unit seperately and the whole unit would need replacing.
Aug 11, 2009 | Heating & Cooling
The outside of my fridge is hot, and the freezer is warming up. If it's the compressor or the "sealed system" the repair visit is totally covered, but if it's something else, I'll have to pay $80. just to...
The side walls of these units are the condensers where heat is rejected to the room air. It is normal. The temperature in the freezer section will rise after a defrost period and the side walls will become hotter right after a defrost is completed due to heat load on the system. Defrost time is only 18-22 minutes normally but the refrigeration system will run longer to recover. Free air circulation is absolutely necessary around these units and nothing should be stored on the top with a towel or other items covering any point.
Jul 29, 2008 | Refrigerators
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
