Question about Maytag Neptune MAH5500B Front Load Washer
On spin cycle the water wouldnt stop runninng in even when i shut it off.flooded my kitchen.it filled up and the door flew open.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.You need to replace the water inlet valve with this part.
Posted on Dec 30, 2010
Nd code, water left in tub with the nd error code. What could be the problem?
sounds like your fill tube has been flooded, there is a plastic tubing that detects water pressure of the water sounds like it has been removed and now has water in it, which is not letting it drain all the way because the vacuum is picking up it is empty when the spin cycle stops and why it stops open the machine if you havent already and look for it the hose and a float valve work together to stop water when full and shut off the pump when empty this seems to be your problem. this fill valve and if it has the fill tube make sure there is no fluid in it also.
Apr 23, 2015 | Washing Machines
Frigidaire convection oven door flyes open during baking pop
I would contact the Manufacturer thru their website and ask for tech support .I have never heard of this type problem
Aug 23, 2017 | Electrolux Kitchen Ranges
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
My machine will not finish a cycle and just stays filled with water.
It sounds as though you either have a clog in the drainage system of the machine, or a bad drain pump.
May 06, 2012 | Hotpoint Washing Machines
Fdb4315lfc2 dishwasher keeps filling up
relay switch is sticking in the open position... the float mechanism tells the unit when to stop pumping water out...
Sep 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Water coming out bottom of door on wash cycle.
you have a bad fill valve. unplug the unit from the wall or turn breaker off and tell me if the water still comes in if the answer is yes you have a bad fill valve.
Jun 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water overflow
Are you on a well? Often people with a lot of sediment in water get sick of the screens in water valve plugging up so they remove them. NEVER remove these screens. If any sediment gets into valve it can hold it open causing flooding. If you unplug unit and water still comes in you must replace valve.
Oct 08, 2007 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune MAH5500B Front Load Washer Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
