Question about Craig 731398407019 Portable DVD Player
Unable to receive dtv signal on model CTV1703
  • 675 Answers
It may be that you need to supply a separate dtv converter box to tune in channels...I don't believe the dvd player has a tuner in it
Posted on Dec 30, 2010
I have sound but no picture. I'm on direct tvI and don't reslly know if its the tv or the dtv receiver. I'm using a hdmi cable. any suggestions on how I can isolate the problem to either the tv...
Hello
Give signal to TV with other devices. Feed it the signal from a DVD player, and see whether there is picture and sound. If it is OK; be sure that the problem is with DTV receiver. OK.
Jun 19, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I have a 32" flat panel. Am only receiving one local TV station channel at this time. All other channels show "No Signal". We hooked another TV to the cable and it works fine. What could the problem...
The tv is good,just some LCD tvs some models require a very strong broadcasting signal to get a picture.U getting a free DTV air broadcasting signal wright?Tries getting a roof antena or a digital design antena.Tries this tv out again,will get all the DTV free air broadcasting signal.Should not get anymore "No Signal" result.
Oct 13, 2010 | Polaroid FLM-3201 Television
I hooked up an antenna but I don't get a signal...do I need a box for my DS24425?
vzalutka,
Your model TV was built with a analog receiver. Last year in June there was a change over to digital broadcasting which left your TV unable to view over-the -air signals without a digital decoder. You will need to purchase a box. I included two site to visit for more information.
http://www.dtv.gov/
http://www.walmart.com/ip/AccessHD-Digital-Analog-Converter-Box-1080D/14869369
-Chris
Sep 11, 2010 | Sanyo DS24425 24" TV
DCT6200 DTV Receiver: the hd channels on my tv skip like it was a scratc...
I may be due to a poor signal to the DCT6200, however if the signal is fine the DCT will need to be replaced.
May 07, 2010 | Arris DCT6200 DTV Receiver
Tv tuner will ot detect digital signal in windows media center, vista
All US TV signals are now digital, but most TV tuners are like our old TVs - analog. Are you sure your tuner is a DTV tuner? If not, you will need to replace it or get a DTV converter. A DTV converter will not let your computer pick the channel and time though.
But one footnote. Broadcast digital TV is often not the same a cable digital TV. If you get a cable digital signal it is encrypted to the actual serial number of the receiving box. No broadcast DTV converter can do this. This is how the cable company now controls the number of receivers and one has to pay for EVERY set.
Apr 23, 2010 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
Hooking a DTV through a router with an amplified antenna
If the input of the tb110mwg was "overdriven" like though an external amplifier; then it IS possible to burn up the receiver.
More than likely you just bought a bad unit. Then again, I would not try to amplify the input signal to the Magnavox unit. This is just not a good idea.
Jan 23, 2009 | Arris DCT6200 DTV Receiver
Digital converter box
Greetings kathy76turne,
In February 2009 you will be unable to receive ANY analog television signals therefore the digital converter box will be a necessity to receive any over the air broadcasts.
I am unable to answer the question about the mini van's electrical capability, however you might find the following link handy to get more information.
http://www.bestbuy.com/site/olspage.jsp?id=pcmcat120600050013&type=category
Thank you!
Dorothy
Go Ahead. Use Us.
Jun 09, 2008 | Mitsubishi HD-6000 DTV Receiver / Video...
Tivo Dtv
No, you need a regular directv receiver, or a directv w/ tivo receiver or a directv dvr.
Oct 03, 2007 | Tivo Humax® HUM-T2500Digital Video...
Craig 731398407019 Portable DVD Player Logo
439 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
